bvh files
Posted By axel.films 6 Years Ago
axel.films
axel.films
Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)Veteran Member (806 reputation)
Posts: 39, Visits: 105
Thanks for your answer.
To "retarget" the figure is obviously not very simple. I suppose that means you have to make a kind of standard T-pose. I don't know how exacty to do that and it seems to me being a very time-taking job. I read somenwhere that you can "load" a T-pose for your figure. When I click on load I recieve a small library but no one of those items work. It is probably better to forget he BVH files.
Axel.
Last Active: 3 Weeks Ago
Posts: 15.8K, Visits: 31.4K
The model associated with the BVH file is imported as a prop. So the first thing you need to do is click "Convert to Non-Standard" under Character in the Modify panel.
You then need to match up (retarget) the bones in the character with iClone bones (my terminology is a bit simplistic as I don't do this normally).
Once the prop is converted to a character you can then export as desired. I was looking for a section in the manual but didn't find any...:unsure:
axel.films
axel.films
Hello,
Many times already someone helped me with a problem so I hope this time there will be someone too.
I imported a BVH file into 3DXChange and exported it (with the animation box checked) to iClone 7.
I find the exported things in the templates as an "iprop file" and also there is a map withe same name in the "Motionlus folder" but that map is empty. So no motion (file) is present in iClone.
I suppose that I am doing the things in a wrong way. How can I use  BVH files in iClone ? Is the way along 3DXChange the wright way? And so yes, what am I doing wrong? At some places I read about the BVH converter but I have no idea where that thing could be. Maybe it is not in use  anymore.
Thanks for any help.
Axel.
