Python crashes iClone when using LoadVocal/GetVisemeComponent
Posted By shane.lessa 6 Years Ago
shane.lessa
shane.lessa
New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)New Member (74 reputation)
Last Active: 6 Years Ago
Posts: 3, Visits: 5
Every time I run my Python script it crashes when using the LoadVocal method on the variable for GetVisemeComponent. It's very important that I get this script automating this process, but any time I give it a go, it just fails completely. Any help would be greatly appreciated
AllenLee (RL)
AllenLee (RL)
Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)
Posts: 54, Visits: 541
Hi shane.lessa,
Could you show me a piece of code of your Python script?
And what is your audio source?
Allen Lee
shane.lessa
shane.lessa
Posts: 3, Visits: 5
Sure thing:
import RLPy
avatar_list                  = RLPy.RScene.GetAvatars()
avatar                        = avatar_list[0]
viseme_component     = avatar.GetVisemeComponent()
audio            = RLPy.RAudio.CreateAudioObject()
audio_path    = "2.wav"
start_time     = RLPy.RGlobal.GetTime()
RLPy.RAudio.LoadAudioToObject(avatar, audio_path, start_time)
clip_name     = "Default"
result            = viseme_component.LoadVocal(audio, start_time, clip_name)
AllenLee (RL)
AllenLee (RL)
Hi shane.lessa,
import RLPy
#This function loads the audio file into the RAudioObject you created.
audio.Load(audio_path
#This function loads the audio into the character’s soundtrack, you can see it in the timeline
Allen Lee
shane.lessa
shane.lessa
Posts: 3, Visits: 5
Thank you for your assistance with this. I found that the issue causing the crash was that the .wav file was not placed in the following path:
C:\Program Files\Reallusion\iClone 7\Bin64
I was assuming that the working directory would be detected as being the same directory as the iClone project file, but in fact iClone reads the working directory as being the path above in 'Bin64'. So either the .wav file had to be placed there instead of the project folder, or an absolute path needed to be used for the .wav file's location.
TLDR:
iClone's working directory defaults to the path above, NOT a project's folder.
