How to make an "iProp"??
Posted By toystorylab 6 Years Ago
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
As Unreal Live Link does not transfer my subprops but a so called "iProp" does work,
how do I make such a thing??
Posts: 5.3K, Visits: 16.8K
Aha! So you are going to animate using bones after all. :)
iProps are props animated with bones with animation recorded to Perform action.
A drawback is, that Perform action in IC7 is broken: https://www.reallusion.com/FeedBackTracker/Issue/Adding-to-Perform-creates-12-16-static-frames-at-the-beginning-of-the-clip/1/Perform
But you may just create clips and apply them where you want it.
Rotation works just fine but you have to rotate Gizmo manually - cannot write the value.
That is all true for a single prop - which is what you need?
toystorylab
toystorylab
Well, this would be in case I don't find an "Unreal-internal" solution for the cars.
BUT, working with Gizmo without "write value" is NO option... :pinch:
There are probably other things I will need where this approach works,
but for the cars I don't really see how it could work properly, without "hick-up"...
@RL
We really need a "write value" option in "Edit Animation Layer" to raise the bar...
I have no clue about programming but is it really so difficult/too much to "change/implement"/... to get that working?
You may convert your car to non-human and animate bone rotations with values in Curve Editor
Actually you do not even have to convert. I tested this car and it works as is - a prop.
toystorylab
toystorylab
Oops, never thought about this approach.:crazy:
Will try that out immediately! (hope I do the 3DXChange process correct :blush:)
Will see what happens... Thanx :P
toystorylab
toystorylab
Done that, not sure how to start in Curve Editor...
Or do I have to start with Edit Animation Layer to have a "start animation" at all to work with?
There:
toystorylab
toystorylab
Got it...
Surely needs a bit practice, but it works!
If it works with Live Link, that's definitely a usable approach... :kiss:
toystorylab
toystorylab
Hm, can't you copy keys in Curve Editor??
You have to add a key first. Either on a timeline or in Curve Editor and then just copy/paste values.
But the clip must be there already before you can manipulate keyframes in Curve Editor
So create a clip be entering a key at the last frame on a timeline (you may delete that key afterward).
And now you may manipulate keys (add/remove) in Curve Editor only.
