aayquemedalarisa
aayquemedalarisa
Visits: 24
Hello, when I choose an audio file as a voice source, only plays the first 5 sg. If I choose TTS or record voice, it plays much longer, without problem. The 5 sg. is a limitation for the standard version?
Last Active: 15 hours ago
All versions of CrazyTalk 8 support audio files up to 15 minutes long. However with the Standard version you can only have one script (audio file) but with Pro and Pipeline you can have multiple scripts. While generally it isn't recommended to use 15 minute audio files because of possible performance issues, you should be fine using shorter audio files. I personally don't have any problems importing any audio files so it may be the audio file itself is the problem. Please try using a different file/audio format to see if it makes a difference.
aayquemedalarisa
aayquemedalarisa
Visits: 24
You're right Peter. it was the audio file. Sorry for the inconvenience. Thank you very much
