05 - "Set T Pose" for Pose and Animation Correction
Posted By Miranda (RL) 6 Years Ago
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Each character has its own initial dedicated T-Pose for Pose and Animations in iClone and Character Creator.  Motions are applied to the skeleton with this T-Pose as the starting point, which implies that this T-Pose is the basis for all motion application which give better and more accurate results when motion files are applied.  Applying motion with the correct T-Pose will give results that are more in line with expectations.
The following processes are currently known to cause changes to the T-Pose, which can be corrected with Set T-Pose
  • GoZ (A-Pose)
  • Import FBX (A-Pose)
  • When adjusting the A-Pose for sculpting:
    • Smaller angles for sculpting the shoulders.
    • Larger angles for sculpting the armpits.
The A-Pose will automatically calculate a corresponding T-Pose for motion application which can be slightly off the mark. For example, a character's A-Pose can be slightly wide (large angle) or slightly narrow (low angle). When the calculated T-Pose does not meet your expectations, then you can recreate the T-Pose at any time by going back to CC and use the Set T-Pose utility.
https://forum.reallusion.com/uploads/images/f006b8c1-97c5-4fcd-8003-8921.gif
Please refer to Online Manual for more details.
Threaded View
