Using CrazyTalk to Export Images of the Different Lip-sync Positions
Category: CT_Hints & Tips_Lip-sync
Version: CrazyTalk 4.5
Date: 2007.01.08
Q: Can CrazyTalk be used to export medium to high quality images of the different mouth positions used in lip synch software? Or, is there another program Reallusion makes that is better for this. I want to create images to be used in another lip synch program that include the standard mouth positions.
Answer: YES -and- No : It will save the original character frame for export as a RL JPEG, but the remaining frames can be exported in a sequence of BMP or TGA by choosing it in "Media Format". The RL JPEG can also be used inside iClone if needed.
Extended Answer:
Save an AVI and use a video frame extractor; then edit that frame in your photo editor of choice. OSS Media Pro can easily do this.
If you only want the default frame, then you just need to save the character inside CT and then select it in the thumbnails panel. Save it as an exported RL JPEG and then edit it in your photo editor. This option only becomes available from the thumbnail panel.
Based on your personal software collection, there are many screen capture programs that can be used to save a selected frame or page. I have multiple editors and capturing software that will do what you asked. You'll have to be creative.
Keeping your Pixels/in at -1- and resizing the image to the width and Height that's suitable for your application will give you the highest resolution.
Is a Reallusion image the only export option within the program itself?
Also, you sound well versed in the program. Are you or do you know any custom software programmers that could use CrazyTalk to create a monk-e-mail type website?
...the remaining frames can be exported in a sequence of BMP or TGA by choosing it in "Media Format".
I've never heard of monk-e-mail, so couldn't help you on that. However there are guidelines with CT and inside this forum for interactive use of the characters on websites; try doing a search here. Takes a bit of standard HTML coding, but I have seen a few websites that are done quite well.
______________________________________________________
Visconti
Forum Moderator
Reallusion, Inc.
https://forum.reallusion.com
17 Years Ago by
Visconti
