Hi...
All you need to do is the following:
1. Create the Prop with a single image.
2. Then take the Prop into Composer mode (top left side panel).
3. Now with the Prop selected, open the Sprite Editor and click the "Add New Sprite" button.
4. You can then repeat this and add more sprites as required.
Then when you return to Stage mode, you can move the Timeline or Play Bar to different frames and use the Sprite Editor again to
switch to the other sprites.
