how do i load multiple media into one sprite
Posted By melockley 5 Years Ago
melockley
melockley
Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)Junior Member (187 reputation)
Posts: 4, Visits: 49
I am using Cartoon Animator pro
I am trying to use sprite switching to create some animation
I have tried following the manual.  i tried 2 different methods:
1.  Tried to use create media - prop.  Then selected multiple images.  They import as separate items in project.  Not a multiple media sprite.
2.  I selected a prop. then selected sprite editor.  It showed the sprite and empty, but i can not figure out how to add more media to the sprite.
Posts: 23.1K, Visits: 36.6K
Hi...
All you need to do is the following:
1. Create the Prop with a single image.
2. Then take the Prop into Composer mode (top left side panel).
3. Now with the Prop selected, open the Sprite Editor and click the "Add New Sprite" button.
4. You can then repeat this and add more sprites as required.
Then when you return to Stage mode, you can move the Timeline or Play Bar to different frames and use the Sprite Editor again to switch to the other sprites.
melockley
melockley
Thanks.
That worked
robert_madrid
robert_madrid
Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)
Posts: 21, Visits: 180
Also it´s possible drag&drop directly all the images.
See: https://youtu.be/VAHdLg73Gbo
