miriamsanderson
miriamsanderson
Visits: 72
Hi, Just a quick question. Is it possible to merge two planes to create a "T" shape which will then display a video in a "T" shape?
Posts: 5.7K,
Quick answer, no. However you could use the "Cross_002" from the 3D Blocks and just scale the Y axis down to 0 (zero), delete the Bump Map in the Texture settings and place the video in the Base Map. You can adjust the X and Z scales to get the size that you need. You should also delete both Metallic and Roughness maps in the Texture settings.
miriamsanderson
miriamsanderson
Visits: 72
brilliant!!
Thank you
Posts: 5.7K,
Happy to help. :)
