Amper Sand
Amper Sand
Visits: 5.2K
Does anybody knows how to create a "slideshow" effect on a plane? From start - video excluded :D
When I realised that object's texture squares are green, I was in heaven, "wow, they are keyframable, I can change plane textures at keyframes, so I will have photo slides!". Well, not so fast, young padawan. So, apart from using video, I didn't find a confortable solution.
Thanks.
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
kungphu
kungphu
Visits: 7.1K
Do you mean swapping out the diffuse material with key frames? I don’t think that possible but would be awesome. That was easily done in Muvizu. Surprised that isn’t possible in iClone but I ha ent found a way aside from pre-assembling the slide show in another program then dragging the video into a plane in iclone.
My "NEWEST" Latest:) Movie Made With Amaaaazing iClone
Posts: 5.3K,
Visits: 16.5K
Make one Base color map and evenly tile your slide images. Then set UV tiles respectively. That is if you have 4 tiles, set U and V tiles to 0.5 Then play with UV offset on the timeline to display them like: U=0, V=0 U=0.5, V=0.5 U=0, V=0.5 U=0.5, V=0 You can slide, or made them stepped with Curve presets. Combine with Glow/Blend channels for some effects... Here I made a basic slide show on a plane
kungphu
kungphu
Visits: 7.1K
Ahhhh... nice workaround. I guess technically it could work with videoed as well. But you’d still need to heavily edited the video to a really weird shape with a split screen. Much more effective with pictures.
