Stethoscope - Concept
Posted By 4u2ges 5 Years Ago
Posts: 5.3K, Visits: 16.8K
Animagic was asking for a functional stethoscope, so I made one based on Rampas' idea.
The prop itself consists separate parts and it is hard to explain how it works altogether.
Download demo and view tutorials.
I cannot say that the soft tube animation is a walk in the park, because it's very fragile. It takes a bit of a practice to animate it successfully and it looks weird until you hit Play.
But it is quite doable. I did not spend much time animating characters, but it's good enough to show the concept.
UPDATE 1/8/2022: Stethoscope is improved to be a bit more robust.
Download demo project and view video tutorials at Marketplace: https://marketplace.reallusion.com/stethoscopeconcept
Last Active: 4 Months Ago
Posts: 5.7K, Visits: 26.5K
The master strikes again. :smooooth:
The bit with the shirt getting pulled up is brilliant, do explain more. :Whistling::blink::ermm:
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
Thanx ;)
Though, as you said, it's no walk in the park...
Tried to use this in another project, but did not work well.
I can't figure out how these locks, esp. the upper ones behave...:blush:
https://forum.reallusion.com/uploads/images/dab63a5d-64f9-4445-8de0-70e2.jpg
rosuckmedia
rosuckmedia
Last Active: 7 Months Ago
Posts: 3.2K, Visits: 4.8K
@4u2ges
Very nice preview video
Thank you for sharing
Will give it a try
Many greetings rosuckmedia:)
tripfreak
tripfreak
Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)
Posts: 2.0K, Visits: 2.8K
Cool, thank you ! :cool:
Thank you guys!
@wires
This is actually a quick one with single morph. It's a lot easier to make such a cloth morph for guys than for girls, where blouse has to go around the breast https://youtu.be/ALXViUbi8rA ;)
I have a Blender tut for this, but it's a little advanced https://youtu.be/lPKkOf3IYZI
@toystorylab
Here is a few tips:
* Disable Opacity map for Stethoscope_flex. You'd see right away that the tube has 2 spherical pockets on both ends to host the main ball locks.
2 balls are inside and should keep the tube mesh locked (ideally lol). Then there are 2 small capsules inside the tube to keep it centered inside upper Stethoscope connector and Diaphragm.
The goal, is animate the way that tube does escape locks at runtime (easier said than done).
* Before you begin animating (linking to the hand) give it a time to settle in the initial position (couple of seconds).
* Avoid sudden (jerky) moves while animating Diaphragm (or rather characters hand since it is linked to it).
Unnatural move of the Diaphragm would twist the tube and result in the escaping from Locks (which is what I see happened on the screenshot).
* The hardest part is to imagine how it would behave at the runtime, since as you see, when animating on the timeline, the tube is all over the place.
* Sometimes Locks are freak out (sort of a bug maybe). You might not really see it right away, but the rigid body of it might get an offset. What I do, is at the frame 1 disable and enable Physics for Locks.
* Now, I see that you have a hidden copy of Stethoscope. Where is it? If it is within close proximity to the one you animate, then it would influence tube behavior.
* Since tube is a soft cloth it would be influenced by any rigid body within close range (even if the rigid object is hidden). Also, out of bound Characters Collision Shapes (or Shapes enabled for the Hand and Forearm) might influence the tube.
Properly positioned body Collision Shapes are actually benefiting by preventing tube penetration inside the body, while Character is standing straight and/or turning the head.
But I would disable Collision shapes for Hand and Forearm and try to grab the Diaphragm the way, that the simulated tube does not come in contact with the hand (On your screenshot I see that it might be interacting).
The less contact tube has with outer rigid objects, the better.
Last Active: 3 days ago
Posts: 15.8K, Visits: 31.4K
What a nice surprise! Thanks 4u2ges!
Physics is always a bit of a struggle for me so this project and your tips will be very helpful.
toystorylab
toystorylab
4u2ges (5/2/2020)
T.H.A.N.X. a lot, this Info was crucial... ;)
Got it working now! And yeah, having 2 flex tubes next to another was thoughtlessly. :blush:
And, NO, I won't make videos with doctors using stethoscopes to do some auscultation on virus models. :D
Ööh, why not? He would probably hear the best Trance-Music he ever heard... :P
https://forum.reallusion.com/uploads/images/7d537dbc-01fa-4458-93f6-ef04.jpg
3dtester
3dtester
Last Active: 6 Months Ago
Posts: 999, Visits: 2.2K
Very nice stuff. iClone is almighty in the right hands :)
charly Rama
charly Rama
Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)
Posts: 1.9K, Visits: 17.3K
Really great work, thank you to share it, nice
