FULL BODY SCALE
Posted By Dan Miller 6 Years Ago
Dan Miller
Dan Miller
Last Active: 7 Months Ago
Posts: 374, Visits: 1.8K
Ok, thanks guys. It does work well to scale (body scale) in iClone, send to CC, and then check object height as suggested. With that workflow I'm able to get the exact height. I appreciate the help.
Posts: 8.2K, Visits: 62.6K
There is an Essential morph for that, but the clothing does not scale well past a small amount. So it's much better to do it in iClone and send back to CC, as Animagic mentioned.
Last Active: 3 Weeks Ago
Posts: 15.8K, Visits: 31.4K
You could scale the character in iClone and then open it in CC3, which would give you OBJ export. You can also see the current height in the Info display (Ctrl+F). You can make some character scale adjustments in CC as well, but it is more limited.
Dan Miller
Dan Miller
Rampa (3/14/2020)
It's in iClone. Look in the attributes tab of the modify panel. Right at the top. The scale there is the best way to do it. Just type in whatever number you want.
Ahh, ok thank you. However, I see iClone doesn't have OBJ export.
Dan Miller
Dan Miller
I'm looking for a global setting to do a full body scale. For example if I wanted the model to be 9.5 cm high. Simply put in the value or slider, or both, end up with a character that is a specific height and everything else is proportional. Does this exist in CC3? I didn't see it in the manual. Thanks.
