Brianna_M
Brianna_M
Visits: 56
I have 5 HP Z400 workstations. I would like to make them into a render farm using iclone 7. I am new to this so I am looking for any ideas or recommendations that would help me do this. Is there anything from Reallusion that would help me with this? I have thought about installing the Realllusion Programs onto each PC and then having them render segments of my sequences but that seems to be a clumsy way to do it. Any help, thoughts or suggestions are appreciated. Thanks.
planetstardragon
planetstardragon
Last Active: 4 Months Ago
Posts: 11.5K,
Visits: 46.0K
to start a render network at home, you'd need software that allows your computers to be linked to work in unison. such as this. https://www.irayplugins.com/iray-server/I use indigo, i don't have the iray plug in so I can't say if this approach would work because I don't know how iclone handles the render files for iray. - but the concept is generally the same for all render engines / render farms - the networking software is generally known as a "network render node"
Posts: 15.8K,
Visits: 31.4K
RL would have to publish render nodes, which currently don't exist, as for rendering you would not need the full functionality, so they could be cheaper. Iray can use multiple GPUs, but they would have to be on the same machine for iClone. I don't think the Iray server can be used.
@Brianna - Are you talking about Iray, or the native iClone renderer?
It's easy to assume you're talking about Iray, but I've had some projects that render slowly in iClone too. If you're talking about iClone itself, I think your "clumsy" approach would be the way to do it. You'd need an iClone license for each computer. You can install iClone on a second machine, but you're only supposed to run one installation at a time. It would be nice to have a "render-only" license. Then you could legally render on one workstation while editing on another.
I've thought about that before. ;)
Issue 3935: Offer a low-cost "Render-only" license for use on additional computers
Brianna_M
Brianna_M
Visits: 56
Thank you all for your responses. I found all your replies helpful and informative if not actually the answers I was hoping for.
I now have more knowledge on this subject than I started with and that has made the post all the more worth while.
Most appreciated.
B.
