Does Anyone Know How To Animate A Winding Rope?
Posted By Lord Ashes 6 Years Ago
Lord Ashes
Lord Ashes
Last Active: 7 Months Ago
Posts: 1.3K, Visits: 1.6K
I'm looking to animate a rope that is attached to a winch on one and and an object on the other end. I want to animate the winch winding the rope and pulling the object closer.
First Attempt: I started with my Physics Enabled cable which is basically a number of segments that are physics joined together with a non-physics shell to make the cable look solid. It is a cable that I am selling on my Marketplace and it has the advantage (over soft cloth) that it can be attached to multiple objects. However this idea failed because the spaces between the physics joints (which are normally not visible due to the mesh cover) allow the cable to pass through the winch axle as the cable is wound-up when I animated the winch.
Second Attempt: Create the winch and rope as soft cloth and make the winch hard cloth and the rope soft cloth. I could not get that working either. Either the winch would fall or the rope was stiff.
Obviously a solution would be to forget about physics and make a long segmented cylinder with bones for each segment so that I could pains-takingly animate the rope manually...but that seems like an incredible about of work.
Any solution that I might have missed or is  the slow and steady manual animation of rope segments the way to go?
Threaded View
Threaded View
Forum Post Does Anyone Know How To Animate A Winding Rope? By Lord Ashes ( 6 Years Ago )
Forum Post It might be possible with Super Bone Editor plugin (Python based)... By 4u2ges ( 6 Years Ago )
Forum Post 4u2ges , that locking mechanism you came up with might work for one,... By Rampa ( 6 Years Ago )
Forum Post [quote][b]Rampa (1/19/2020)[/b][hr]I also did something like that... By Lord Ashes ( 6 Years Ago )
Forum Post I was too intrigued to wait till tomorrow :) This is possible, but the... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (1/19/2020)[/b][hr]To spare explanation I have... By Lord Ashes ( 6 Years Ago )
Forum Post I'm trying to reproduce similar effects as those in Rampa\4u2ges... By Lord Ashes ( 6 Years Ago )
Forum Post Awesome! :) I will obviously need to copy your locking mechanism. It... By Rampa ( 6 Years Ago )
Forum Post The answer is actually simple. Rigid Self-mesh body and soft cloth do... By 4u2ges ( 6 Years Ago )
Forum Post Assuming the rope/cable is taught... why bother with physics at all?... By illusionLAB ( 6 Years Ago )
Forum Post [quote][b]illusionLAB (1/19/2020)[/b][hr]Assuming the rope/cable is... By Lord Ashes ( 6 Years Ago )
Forum Post Thanks. That answers both the question about the separate winch... By Lord Ashes ( 6 Years Ago )
Forum Post One other important detail is that the solver frequency must be set... By Rampa ( 6 Years Ago )
Forum Post [quote][b]Rampa (1/19/2020)[/b][hr]One other important detail is that... By Lord Ashes ( 6 Years Ago )
Forum Post I don't mind at all Lord Ashes. Feel free to use it in your projects... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (1/21/2020)[/b][hr]I don't mind at all Lord Ashes.... By Lord Ashes ( 6 Years Ago )
Forum Post A cylindrical unwrap, or unwrap following quads should work. The... By Rampa ( 6 Years Ago )
Forum Post [quote] I found a way to more or less the same thing using just 4... By 4u2ges ( 6 Years Ago )
Forum Post An internal sphere works too! :) By Rampa ( 6 Years Ago )
Forum Post lol You finished it! This is a wonderful idea. Inner sphere lock is... By 4u2ges ( 6 Years Ago )
Forum Post Now we have a truly flexible cable that can be controlled from either... By Rampa ( 6 Years Ago )
Forum Post Yes, so the weight map could be potentially all white. I was thinking... By 4u2ges ( 6 Years Ago )
Forum Post The hidden faces not staying hidden would be a bug. :( So I'm... By Rampa ( 6 Years Ago )
Forum Post And here is a start. :)... By Rampa ( 6 Years Ago )
Forum Post Turns out all you need to do is put a cube inside the cable tube, and... By Rampa ( 6 Years Ago )
Forum Post The cube stopper is good too, bur I still prefer a sphere one you came... By 4u2ges ( 6 Years Ago )
Forum Post I found the 4u2ges is good but, for me, it snapped out when the... By Lord Ashes ( 6 Years Ago )
Forum Post That looks good Lord Ashes. I would not however disregard the ball... By 4u2ges ( 6 Years Ago )
Forum Post [quote][b]4u2ges (1/25/2020)[/b][hr]That looks good Lord Ashes. I... By Lord Ashes ( 6 Years Ago )
Forum Post Now I have run into two issues with the next phase: the unwind. 1.... By Lord Ashes ( 6 Years Ago )
Forum Post I would delete the tray and insert a physics floor from the create... By Rampa ( 6 Years Ago )
Forum Post [quote][b]Rampa (1/25/2020)[/b][hr]I would delete the tray and insert... By Lord Ashes ( 6 Years Ago )
Forum Post Interesting...Rampa's cable does not have ballooned ends like I... By Lord Ashes ( 6 Years Ago )
Forum Post Found a solution to the unwinding problem which actually solved both... By Lord Ashes ( 6 Years Ago )
Forum Post Rampa/4u2ges are you selling your lock based tube/rope/cable in your... By Lord Ashes ( 6 Years Ago )
Forum Post I had pretty much forgotten I had a store, from ages ago. I have no... By Rampa ( 6 Years Ago )
Forum Post @Lord Ashes Quite frankly the idea of creating pockets might not be... By 4u2ges ( 6 Years Ago )
