Curve editor fail again
Posted By blindman 6 Years Ago
blindman
blindman
Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)Veteran Member (948 reputation)
Posts: 57, Visits: 372
The curve editor stopped  working again a couple of weeks ago, when I checked I needed some updates to the iclone programs which I installed and that fixed the problem. so now I have all the latest updates an yet  I find again the curve editor has stopped  working properly. Transitions appear but when selecting  layer keys the graph area goes a very dark gray and the scrub function doesn't work with the indicator stuck..... I also notice in iclone when animating figures (Standard iclone) that when key framing the motion layer instead of getting an motion area that grows in duration with the keys. Each key frame creates a individual motion block 1 frame in duration. The animation layer for objects however works fine
Bringing in a motion creates a motion area as normal. I can then add key frames as normal in this motion
But the ability to build a motion area  from my own keyframes is gone !!!!
any ideas
