Equivalent to initialize_plugin() called on exit?
Posted By will.cowling.uk 5 Years Ago
will.cowling.uk
will.cowling.uk
Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)
Posts: 11, Visits: 115
Hi,
If I'm writing a iClone plugin using the python API, then in my main.py the function initialize_plugin() is called when it starts up.  What, if anything is called when the plugin/application exits?
I've tried uninitialize_plugin, destroy_plugin, shutdown_plugin.  Is there something like this available?  Is so, what should the function be called?
Thanks,
Will
jlittle
jlittle
Last Active: 4 hours ago
Posts: 1.9K, Visits: 17.1K
Here is what I have done:
Create a procedure to be executed upon exit:
def onExitProc(result):
In this procedure unregister any event callbacks, etc.
Then, in the initialization procedure where you create your app dialog window, connect the exit procedure to the dialogs finished event.
myDialog = create_dialog()
# setup exit proc
myDialog.finished.connect(onExitProc)
Then when you dialog closes it will execute your exit procedure.
The procedure create_dialog() is my routine that creates my apps window, loads the Qt info, and connects all the buttons events, etc.
Hope that helps.
Jeff
5 Years Ago by jlittle
will.cowling.uk
will.cowling.uk
Many thanks for the info.  Could you clarify what type myDialog is in your example?  Is it an RlDialog created with RUi.CreateRDialog?  Or something else?
Thanks,
Will
5 Years Ago by will.cowling.uk
jlittle
jlittle
Will,
Here is a striped down version of one of my programs:
import PySide2, RLPy, os
from PySide2 import *
from PySide2.QtCore import *
from PySide2.QtCore import QResource
from PySide2.QtCore import QFile
from PySide2.QtCore import QIODevice
from PySide2.QtGui import *
from PySide2.QtUiTools import QUiLoader
from PySide2.QtWidgets import *
from PySide2.shiboken2 import wrapInstance
import csv
myDialog = None
eventCallback = None
eventCallbackId = None
# event callback class
class MyEventCallback(RLPy.REventCallback):
def __init__(self):
RLPy.REventCallback.__init__(self)
def OnObjectSelectionChanged(self):
icpropSelectionChanged()
# on exit cleanup procedure
global eventCallbackId
# unregister event handler
status = RLPy.REventHandler.UnregisterCallback(eventCallbackId)
# initialize
def initialize_script():
global myDialog
# register RL event callback
eventCallback = MyEventCallback()
eventCallbackId = RLPy.REventHandler.RegisterCallback(eventCallback)
if myDialog is None:
# setup exit proc
myDialog.show()
# create the main dialog window
def create_dialog():
global myDialog
main_widget = wrapInstance(int(RLPy.RUi.GetMainWindow()), PySide2.QtWidgets.QWidget)
dlg = PySide2.QtWidgets.QDialog(main_widget) # set parent to main window
# Load Qt Ui file into ui_widget
ui_file = QtCore.QFile(os.path.dirname(__file__) + "/uiLayoutFile.ui")
ui_file.open(QtCore.QFile.ReadOnly)
ui_widget = QtUiTools.QUiLoader().load(ui_file)
ui_file.close()
# Make the RL Dialog
ui_dialog = RLPy.RUi.CreateRDialog()
# Wrap to PySide Dialog
pyside_dialog = wrapInstance(int(ui_dialog.GetWindow()), QtWidgets.QDialog)
ui_layout = pyside_dialog.layout()
ui_widget.hide
ui_layout.addWidget(ui_widget)
dlg.setLayout(ui_layout)
return dlg
# Start Script
def run_script():
initialize_script()
Jeff
will.cowling.uk
will.cowling.uk
Awesome, many thanks.
Thanks for posting the code.  It's much clearer now.
Cheers,
Will
