How to keep same Character position between two motions
Posted By hirospot 6 Years Ago
hirospot
hirospot
Posts: 241, Visits: 5.9K
Re: Character Position (Fixed)
  Character Position is now shown on the Transform/Move display on the  updated iClone7.5.3
  Reset (Zero Out) button works now.
https://forum.reallusion.com/uploads/images/c762bd07-516e-41ab-8359-9fb3.jpg
Thank you,
Hiro
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
Here it is:
toystorylab
toystorylab
In "Edit Motion Layer" you can set a pose as default (Set as Default).
If you want your character to get into this pose somewhere else in the timeline, simpy click on "Default" in "Edit Motion Layer"
and your avatar will be posed exactly the same pose as "set to default" pose.
Be carefull if this pose is very different to the pose of the motion you use this.
You will have to click on "Reset" some frames later so it gets into the correct poses of the second motion.
I hope you get what i mean...
https://forum.reallusion.com/uploads/images/526c49df-f9ca-4b0b-aa8e-de39.png
Rampa posted here in the forum a tutorial about this...
hirospot
hirospot
Are there good way to keep the same character position when applying the two different motions.
  1) Locate the character to Reset(Zero Out) at Transform then apply first motion.
  2) Move Timeline and put second motions at the end of first motion
  3) The character position changes, but the X and Y value do not change in Modify/Transform /Move.
       X and Y value used to change in iClone6.
This happens only in iC7?
Need to keep the character on the same position. How in iC7?
If you move the character to the Reset position manually, unexpected transition move happens.
https://forum.reallusion.com/uploads/images/a39b3485-06b2-4f14-96ce-46ff.jpg
https://forum.reallusion.com/uploads/images/628d1c5c-8174-4259-ac26-0feb.jpg
Thank you,
Hiro
