Sunrise765
Sunrise765
Visits: 290
Is there a way to use PopcornFX to make snowfall to the ground, if so, is there a video or instructions I can follow? I just can't get the one in Popcorn to work. Thanks
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
I add some features with this free template from the editor V1.12. It's the "Nat_Snow" in the Particles/Environment folder of the editor. https://drive.google.com/file/d/1D5rgEWtX4mYac7utsAJdkIyqtyQJHxqA/view?usp=sharing
Last Active: 3 days ago
Visits: 62.6K
Many of the Popcorn effects rely on physics. Enable physics on your ground plain or prop. Make sure it is set to static in the physics panel, so it does not fall away.
Another option is to use a "snow effect" in Post... meaning in your video editing software (NLE). It can quite easily produce an effective result if you just want falling snow to appear.
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
I only once used the Popcorn FX Learning Samples "Snow": And i found it hard to have a lot of snow without chocking my PC. I had at least 15 of the Snow-particle running all over the place and that was too much. I reduced to 8 and linked 1 to the snowcat and 1 to my camera... That helped. If you make your ground white, you don't need it to "fall on the ground". But if you want this effect; a clean ground getting white, you will have to do it as Rampa said: Create - Physics - Infinite Plane Set Physics of "Arrow" to Kinematic Set Particle Life Max to 2000 Set End Opacity to 1.00
kungphu
kungphu
Visits: 7.1K
Well done TSL, this looks great!
My "NEWEST" Latest:) Movie Made With Amaaaazing iClone
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Can i import this with the IC7 internal PopcornFX Plug-in?? When i do so, i get an error:
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
kungphu (7/20/2019) Well done TSL, this looks great! Thanx...
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Import it first in the Editor (V1.12) with an Iclone axis orientation , save it , then import it in Iclone. It should works.
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
mtakerkart (7/23/2019) Import it first in the Editor (V1.12) with an Iclone axis orientation , save it , then import it in Iclone. It should works.Yo, worked! T.H.A.N.X. Way better than the original... (at least if you want a more heavy snow)
