This is probably really something you should learn to do yourself. Doing opacity maps is not difficult and you don't have to be a great drawer.
Im not sure what it is you don't know what to do, I'm guessing its 2D editing so here is how.
Step 1
you need a 2D editor. I mostly use paint dot net because its easy to use and is free.
Step 2
You need to show iClone where your 2D editor is. Here is how to do that
Step 3
Then you can send an objects images to your 2D editor for editing it
Here is how to send the Opacity map for editing. You can also do this with the other objects images too
Step 4.
When completed the editing of the image just save it to automatically update the object in iClone
Here is an example of the result
OK, those methods work fine when its easy to tell where to paint things on the image so they appear in the correct place on the object your adjusting.
When its not so easy to tell where to paint things so it appears correctly on the object you should use the method of doing it with UV map
Step 1
Send the UV map to the 2D editor
Step 2
You cant save and automatically update the object in iClone when doing it this way. You need to save the image to your computer and then load it into the objects texture manually.
If this is not what you don't understand the you need to very specifically explain what it is you don't understand. Then people know what to answer with
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
