How to detach an attached prop?
Posted By tallon 7 Years Ago
tallon
tallon
Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)Veteran Member (901 reputation)
Last Active: 6 Years Ago
Posts: 24, Visits: 119
Hi,
I need my character to carry a prop I've created and place it on the ground.   I'm attached the prop to his hands, and I'm using the 'Occupations>Courier' pack animations for the walking and placing, but don't know how to DETACH it when he puts it on the ground.
This is what I've done so far:
- I've created the prop and added it as a 'custom prop'
- using Composer mode I've attached it to his hands - and on the correct layer so it appears between his arms when he walks
- I now need to detach it when he places it on the ground (and walks away)
(I tried using another instance of the prop with visible/invisible settings but it seems there is no place on the character Z axis that is between his arms - only when you add the prop in composer mode)
Am I missing something simple or just doing this the wrong way?
Thanks,
D.
Threaded View
Threaded View
Forum Post How to detach an attached prop? By tallon ( 7 Years Ago )
Forum Post You have to make it invisible once it is on the ground and replace it... By vepop ( 7 Years Ago )
Forum Post For this case, use " LINK " rather than Attach. When you want him to... By justaviking ( 7 Years Ago )
Forum Post I don't think using LINK can place the prop in between the arms. By vepop ( 7 Years Ago )
Forum Post When he said "attached it to to his HANDS," I didn't really notice... By justaviking ( 7 Years Ago )
Forum Post I've attached it (a letter 'X') to just one hand and the way it moves... By tallon ( 7 Years Ago )
Forum Post D'oh! So sorry... I used the "Latest" view for the forum, and forgot... By justaviking ( 7 Years Ago )
Forum Post When you add a prop to a character, in composer mode, you are adding... By jlittle ( 7 Years Ago )
Forum Post Thanks jlittle for that info - I think I understand it a little better... By tallon ( 7 Years Ago )
Forum Post As vepop suggested, you need to make the character prop invisible at... By jlittle ( 7 Years Ago )
Forum Post Yes, I understand that suggestion, but it would look crap because it's... By tallon ( 7 Years Ago )
Forum Post Here is a quick test of a character prop dropped, turned invisible and... By jlittle ( 7 Years Ago )
Forum Post Hi Jeff - many thanks for that. I see what you mean about having to... By tallon ( 7 Years Ago )
Forum Post Hi, How about having a different camera viewpoint? Once prop is... By vepop ( 7 Years Ago )
Forum Post Thanks for those suggestions - the change of camera wont work for what... By tallon ( 7 Years Ago )
Forum Post The double character, as vepop suggested, is probably your best bet.... By jlittle ( 7 Years Ago )
Forum Post That's what I tried, but it's impossible to place the new item between... By tallon ( 7 Years Ago )
