Rampa (3/11/2019)
accessorYou can import all the clothing and auto-rig it in CC3. There is also weight mapping tools for additional touch-up.
You don't even really need a Tpose. You can pose the character to your clothing, and then auto rig. Also note that in 3.04, there is an "Accessory" item in the Create menu. That is now how you import OBJ, and even FBX to rig to your character.
If you import your existing clothed characters through the Create/Accessory menu in FBX format, the clothing will all import as separate items. The body will to, and you can just delete it. Bones will not be imported. 3.04 only, for FBX accessories.Although that works for clothing; the problem is that I have a figure that I want to import first.
Imagine I want to make a clone of an anime character; my first step is to modify the base CC3 character look and proportions; and sadly the DAZ figures are more on the realistic side than the anime/cartoon side, so can't use that as starting point
Unless I misunderstood your post; I can ony import OBJ or skinned DAZ figures
