What's New in Iray Render Plug-in v1.11
Posted By Tony (RL) 7 Years Ago
Posts: 8.2K, Visits: 26.5K
Fantastic!!!
It's great to see improvements continue even after the initial release.  Great job, Reallusion.
Posts: 5.7K, Visits: 26.5K
Excellent list of fixes Tony. :):cool::smooooth:
sonic7
sonic7
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Posts: 1.7K, Visits: 19.4K
Thanks! .... that 'Firefly' solver is great news .....  :)
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :(  - yikes! ...
MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram iClone-7.93  3DXChange Pipeline 7.81  CC-3 Pipeline 3.44  Live Face  HeadShot  Brekel Pro-Body  Popcorn FX  iRAY  Kinect V2  DaVinci Resolve17  Mixcraft 8.1
Tony (RL)
Tony (RL)
Last Active: 6 Years Ago
Posts: 222, Visits: 1.7K
Added: Render Log for Standalone Renderer [FT5289]
Standard procedure for the Iray Standalone Renderer 1.1 was to automatically close after completing the render task.
Instead of closing down, version 1.11 stays open after render completion and allows the user to save a render log file via the Show Log button.
Added: Nominal Luminance for Solving Fireflies [FT5258]
https://forum.reallusion.com/uploads/images/8dfbf4f5-3c06-4cd3-ad22-ddae.png
New Nominal Luminance option for the render settings.  Use Nominal Luminance to reduce the firefly effect (bright whitish spots that can afflict a render when high powered light sources are used).  Lower Nominal Luminance values equate to stronger suppression of fireflies.  However, when this value is too low, then lighting details may be lost in the final render.
Example :
Sample Iterations = 400
Nominal Luminance = Off
https://forum.reallusion.com/uploads/images/2f7cb85a-8605-4bee-be1b-1d26.png
Nominal Luminance = 50
https://forum.reallusion.com/uploads/images/db3af10c-7e3e-4c7f-93c5-ef29.png
At extremely low values, light details for high powered lights may be lost.
https://forum.reallusion.com/uploads/images/5b6e6f06-5bcc-4bd2-ac7f-0df8.png
Enhanced: Changes to Sequential Numbering for Batch Renders [FT5446] [FT5662] [FT5679]
Sequential numbering for batch renders in Iray 1.11 resulted in the insertion of the order number in midst of the image filename.  This made it impossible for other software to recognize the sequence of the frames.  Therefore, for version 1.11, the order number is now inserted  to the back of the filename.
https://forum.reallusion.com/uploads/images/be77d25c-32b8-4f2b-8ef5-bbf6.png
Enhanced: Improved Usability for Auto-convert MDL User Interface (Enable/Disable).
Before:
https://forum.reallusion.com/uploads/images/5d215486-5a00-4821-b66e-671c.gif
After:
https://forum.reallusion.com/uploads/images/980e44b0-fcb2-4299-8ffc-eba6.gif
Fixed : Incomplete frames as a result of rendering MI files that contain Speedtrees which go in and out of the camera viewing area. [FT5613] [FT5712]
Fixed : Artefacts in the alpha channel for images rendered from projects with transparent backgrounds and Denoiser enabled. [FT5621] [FT5709]
Fixed : Closing iClone had the tendency to close the Iray Standalone Renderer as well, if it was called from the iClone application in the first place. [FT5664]
Fixed : Batch rendering oftentimes had failed to reach the Stop Criteria when executed from Render Scene > iClone Render. [FT5685]
Fixed : Add or removal of the an IES profile from a light had a tendency to reset its Intensity Multiplier to the default value of 1.
Tony
Product Marketing Manager
