Smooth transition between two clips without stutter?
Posted By whistlebare 7 Years Ago
whistlebare
whistlebare
Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)Veteran Member (893 reputation)
Posts: 35, Visits: 360
Hi...i'll get straight to the point and try and explain this as best as i can.  Is there a way of aligning all body parts between two different animations without having to manually edit the animation layer?  I can't use a transition clip as it sends my character away from it's original location for a split second and then jumps back.  I've been using the align option to keep the character in the right place between transitions, but the rest of the body parts are slightly out of position and this causes a stutter between the clips.
For extra info, i have the character linked to a dummy prop to help keep him where i want him
https://forum.reallusion.com/uploads/images/a3ce783f-3d71-4cd0-9732-5d8b.png
