I put together a simple class that makes it easier to use the iClone system events.
I created this to help make my scripts simpler and cleaner.
Basically all you have to do is:
- import the class
- create the object
- assign your event handler procedures
- delete the event handler object on script termination.
All the registration and un-registration of the event handler is handled in the class.
Example:
# import MyiCloneEvents class from the file iConeEvents.py
from iCloneEvents import MyiCloneEvents
# create the RL events handler object
iCloneEvents = MyiCloneEvents()
# set up my script event handlers for the iClone events desired
iCloneEvents.setOnBeforeLoadFile(onEvent_BeforeLoadFile)
iCloneEvents.setOnFileLoaded(onEvent_FileLoaded)
iCloneEvents.setOnAfterFileLoaded(onEvent_AfterFileLoaded)
iCloneEvents.setOnBeforeSaveFile(onEvent_BeforeSaveFile)
iCloneEvents.setOnFileSaved(onEvent_FileSaved)
iCloneEvents.setOnObjectSelectionChanged(onEvent_SelectionChanged)
iCloneEvents.setOnObjectAdded(onEvent_ObjectAdded)
iCloneEvents.setOnObjectDeleted(onEvent_ObjectDeleted)
iCloneEvents.setOnPlayed(onEvent_Played)
# on script termination delete the events handler
del iCloneEvents # Note: the event handler object unregisters on deletion
I've included a script (iCloneEventsTest.py) to show how to use it.
The important thing to remember is to delete the object when the script terminates.
This will un-register the event handler from the RL system. If the event handler is not not un-registered then system events will still try to call the event handler which can/will cause iClone to crash.
How your script terminates depends upon your script. The example I provided uses a blank dialog window that when closed uses the "finished "signal to delete the object.
Jeff
