import PNG file into Iclone 4
Posted By magicbon 15 Years Ago
magicbon
magicbon
Posted 15 Years Ago
Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)Junior Member (245 reputation)
Posts: 2, Visits: 47
I have some PNG files with transparency. Import a background and want this file to appear in Front of the background with background showing behind. Everytime I import the Png file, it becomes a new background.
I know I am doing something wrong. Any advice would be grestly appreciated. I am loving this program.
I am using Iclone 4 PRO.
thanks.
magicbon:)
Cricky
Cricky
Posted 15 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
Apply your PNG w/alpha to a Flat Plane. Size it to fit your situation. It's movable and sizable. Applying it to the 2D Background will not do what I envision you are attempting. Use whatever image you want as the 2D Background, but place the Flat Plane in front of it to use the opacity built in. You'll find a PLANE in 3D Building Blocks under '3D Space' or '3D Surface.
You could also apply the PNG w/alpha to an Image Layer, but you are limited in sizing it by height and width only and it cannot be moved forward and backward.
magicbon (2/7/2010)
thanks.
magicbon:)
SKYPE ID: rc.650
tripfreak
tripfreak
Posted 15 Years Ago
Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)Distinguished Member (8.7K reputation)
Posts: 2.0K, Visits: 2.8K
Or simply press CTRL while dragging the image into the working window.
I think, this should also work. :)
mmhbcn
mmhbcn
Posted 15 Years Ago
Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)Senior Member (393 reputation)
Last Active: 13 Years Ago
Posts: 57, Visits: 512
tripfreak (2/8/2010)
It works perfectly this way. Thanks for the tip.
