iClone 7.5 (with new Python APIs ) is Available!
Posted By luke (RL) 7 Years Ago
3
4
5
6
7
dogged2003
dogged2003
Posts: 418, Visits: 4.5K
RobertoColombo (2/4/2019)
DEVELOPMENT version has completely overwritten the stable 7.41.
  Roberto
How did you get this version?
My YouTube channel.
Zeronimo
Zeronimo
Last Active: 6 Months Ago
Posts: 482, Visits: 19.3K
luke (RL) (2/6/2019)
zeronimo (2/5/2019)
YES, after doing PLAY the GIZMO and the transform coordinates are updated.
What disturbed me was that the color of the light and the multiplier was up to date but not the coordinates of transform before the PLAY.
Some UI update will have the performance issue so we disable that, and we will give you a function to force UI update in further patch, however the data already set down no matter the UI show up or not.
thanks for these precision Luke
RobertoColombo
RobertoColombo
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.6K, Visits: 3.0K
Thanks Luke.
Right now I had already installed the DEVELOPMENT icLone, so the stable one got overwritten :-(
Actually I am not clear what do you mean with copying the whole directory...  would like to not touch the stable version but rather having teh development one that sits in a user-chosen place, with no installer, so that we can easily remove.
Another point: ff possible, in a future patch, can you add an API to terminate the plugin script, without closing iClone, so that we can setup a robust error management ?
I tried different ways, but so far with no luck...
Regards
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
The-any-Key
The-any-Key
Posts: 356, Visits: 1.9K
The-any-Key (2/4/2019)
Some examples to get and set the rotation quaternions for objects in local and world (or a way to transform world to local and set it or vice versa).
Also the API update gives me this error when trying to start iClone
https://forum.reallusion.com/uploads/images/9464a89a-72d2-4081-a59d-8179.png
Translation: Could not find the address (memory pointer) to start the process.
Could you send me the dump file? I could check it when I back from lunar new year
After I uninstalled iClone and then re-installed it. The dev version installs and works fine :-)
luke (RL)
luke (RL)
Group: Power Developer
Posts: 289, Visits: 5.6K
zeronimo (2/5/2019)
luke (RL)
luke (RL)
My version starts fine... but I do not like that this DEVELOPMENT version has completely overwritten the stable 7.41.
That's not what i wanted when I downloaded and run it.
Now if I want to create some scene in parallel with Python development I am not sure whether any project created with this temporary version will ever be recgnized by a stable one
RL should have create a standalone .exe, which does not install anything, like was done in the earlier stages of IC7 Beta testing.
  Roberto
Okay, we will think about how to give you the full installer or a zip file rather than replace current one  before that, I suggest you to backup the official version (copy whole iClone folder to other place) then update to the development one, so you should get both version to run in your computer
luke (RL)
luke (RL)
RobertoColombo
RobertoColombo
I had the same issue, reported in the Forum some time ago: the XYZ coordinates were not updated in real time, but rather only after I pressed PLAY.
RL mentioned that this is to guarantee a certain level of performance, which might sounds ok for certain plug-ins, which algorithmically create a fixed situation, i.e., not controllable in real-time, but it is surely not ok if we want to try to create real-time controllers.
Just a simple example/challenge for who wants to take it: moving a prop in real-time with the mouse and creating the prop keys accordingly (kind of old iClone "Director Mode" or also the Physics Toolbox, regrettably dismissed by RL).
Creating teh jkeys using a system timer is surely possible but... how to visualize the result in real-time if the GUI updates only after we press PLAY ?
Cheers
  Roberto
My PC:
Posts: 9.2K, Visits: 22.1K
For some reason the UI doesn't update properly when running Python -- I don't know if that will ever be fixed, although the key guy here says you can put a hide/unhide object in your code so it gets fixed.  Kind of.  But it IS a bit disconcerting.
Zeronimo
Zeronimo
3
4
5
6
7
