When you "saved it" did you mean you saved it as a "Scene"?
A "Scene" object contains multiple objects to make up that "Scene" and if you saved your Stage setup then you created a "Scene" object containing all your props.
Saving a "Scene" object
Will Not Save Any Animation for that "Scene".
You can
only have one (1) "Scene" object on the stage at a time.
Loading another "Scene" will not Combine the "Scenes" but Replace the previous "Scene" since only one "Scene" object at a time is allowed.
"Scenes" are used to setup your Stage quickly to start an animation. You would not normally change "Scenes" in the middle of an animation.
If you need to change "Scenes" then create a new project for the next "Scene" you need to use.
Jeff
