Issue 4: Importing another Crazy talk file
Posted By hi_022884 7 Years Ago
hi_022884
hi_022884
Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)Veteran Member (879 reputation)
Last Active: 6 Years Ago
Posts: 20, Visits: 36
How to import another CrayTalk Animator3 file to an existing file.
Means if I have customized or animated a character or a prop in a file then how can I use that customized or animated character in another animation file?
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
Once a character is on the Stage you can select that character (or Prop) and then click on the plus (+) button in the Content manager to save your creation to the Custom area.
Once save, you can then add that object to any scene or new project.
Jeff
hi_022884
hi_022884
Thanks
hi_022884
hi_022884
One issue raised just now when I did the same action with the scene.
I Animated a scene (say Ani1) and saved it using + sign. When I opened another file Ani2 and used that saved animation scene (Ani1), This Ani1 swapped the previous file's scene. Rest of the things were in the place but it replaced the old scene. Also, the animation I did in Ani1 file could not be seen. Some mess created. Please help.
jlittle
jlittle
When you "saved it" did you mean you saved it as a "Scene"?
A "Scene" object contains multiple objects to make up that "Scene" and if you saved your Stage setup then you created a "Scene" object containing all your props.
Saving a "Scene" object Will Not Save Any Animation for that "Scene".
You can only have one (1) "Scene" object on the stage at a time.
Loading another "Scene" will not Combine the "Scenes" but Replace the previous "Scene" since only one "Scene" object at a time is allowed.
"Scenes" are used to setup your Stage quickly to start an animation. You would not normally change "Scenes" in the middle of an animation.
If you need to change "Scenes" then create a new project for the next "Scene" you need to use.
Jeff
