Hair Alpha channel not working as it should.. need help!
Posted By Berdy 6 Years Ago
Berdy
Berdy
Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)Veteran Member (584 reputation)
Posts: 3, Visits: 34
Hi there,
I'm rendering a CC character in 3DSMax with the Redshift renderer.
The hair's alpha channel pushes right through the head, almost like a matte.
Please can you help?
https://forum.reallusion.com/uploads/images/42f95498-fb61-40b4-a0d5-1fcf.png
Last Active: 8 hours ago
Posts: 15.8K, Visits: 31.3K
It looks like Specularity is way up for the skin. To test, remove the hair. My guess is that you will still see the white areas. They will also change position when you move the lighting.
Depending on the Max shader, you will have to adjust Specularity or Roughness (in case it is PBR). I don't have Max, so I can't check myself.
Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)
Posts: 8.2K, Visits: 62.4K
I've seen similar happen in Unity. Try playing with shader options for the hair and scalp you have available in Redshift.
I assume you can use different shaders in Redshift that may do better job. Make sure the shader used for the hair is only used for the hair.
6 Years Ago by Rampa
Berdy
Berdy
Fixed.. Thanks for the replies.
I used a sprite node in Red-Shift, which solved the issue.
So it was a shader issue in the end.
Thanks!
