I cannot get animated gif to repeat motion
Posted By Chucks -7600 6 Years Ago
Chucks -7600
Chucks -7600
Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)
Posts: 11, Visits: 95
Using CTA 3 Pipeline, I created an animated gif which only animates 1 time after exporting.
Regardless of which program I use to play the file, it will only animate 1 time. I clicked on the "Loop" feature but it will not loop.
Any ideas?
tripfreak
tripfreak
Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)
Posts: 2.0K, Visits: 2.8K
Often, it helps to simply remove the last frame and to save it again.
E.g. with Virtualdub:
1. Use the marks to select the last frame and then cut it:
https://forum.reallusion.com/uploads/images/6ec92cb3-cb28-4a7f-a8a3-ff4d.jpg
2. Export as "Animated GIF":
https://forum.reallusion.com/uploads/images/d374470b-af30-4ba0-9f07-0ff1.jpg
3. and activate the "Infinite loop":
https://forum.reallusion.com/uploads/images/5938dca6-ec92-47eb-9254-cdbe.jpg
Done !
Now it should (hopefully) loop.
Good luck !
Chucks -7600
Chucks -7600
Thank you. I will give it a try!
