Here are some screen shots of the things I said in case you have difficulty finding them
The red box I added shows where to make the object visible or invisible as it animates
This one shows where you selects all the frames and then add it to the prop as a performance
This one shows where you can perform the performance.
Notice there are 2 that I added.
You can create an animation and add it to the prop as a performance.
Goto frame 1 and remove the animations
Create another different animation and add it to the prop as another performance.
Repeat that process to create all the different animations you want the prop to be able to do.
When done that you can save the prop so whenever you reload it it will automatically have all those performances for you to use however you want.
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
