Hi
one thing I have always struggled to understand in any version of iClone is the diffuse UV settings ie tile and offset. In particular tile.
The iClone manual doesn't do a very good job of explaining the functions and I can't find any decent tutorial videos in regards to it.
What I am trying to right now is to add an image or even a video to a car rear vision mirror.
No problems adding the image or video to the prop surface, however I have no idea what I am doing with the tile settings to get the diffuse to appear properly. At the moment it's just streaked lines. When I change the tile settings, the image does change, but I can't tell if it's making it worse or better. I just don't understand what the 'U' and 'V' are supposed to represent. So I've just been randomly sticking different numbers in trying to find a combination that displays the image properly. But I've spent over an hour on it and no closer.
Is it just a matter of trial & error ? Or is there some sort of method behind it ? At this rate I'll never get the combination right.
If someone understands the process, I would be much appreciative if you could explain it to me
thankyou!
Darren
*edit
been doing a bit more experimenting
I have loaded the video onto a plane and then attached the plane to the prop/mirror.
Seem to be able to effectively scale the video to fit using tile now.
Maybe loading the video to the diffuse channel of the prop isn't such a good idea ?
_________________________________________________________
