I checked out the newer videos and the manual but I still am stuck on a couple things.
** Going from Character Creator to
Unity3D use to be: Character Creator - Make your character > Move it to 3DX > Export to FBX with settings for Unity. If you wanted animations you moved it from CC > IClone then 3DX.
** So is it now Character Creator > Export directly to Unity FBX setting? Unless you want animation then you would go from Character Creator to IClone then ...where to export? Back to Character Creator or through 3DX?
** Also in Character Creator and IClone 6 direct FBX export to Unity did not work properly so I would have to move it to 3DX to Export, there were also settings in the export panel to select is that still needed or does the exporter now auto-set it for Unity Export?
** Does this also apply to things like the animal pack (I have the Export license) Do those still (I assume) go from IClone > 3DX > Unity 3D?
Thank you very much for the help in clearing this up.
