mariusjensen01
mariusjensen01
Visits: 2.2K
Indigo plugin is not working in IC 7.3. IC7.just breaks down, when I try to render a picture with the indigo plugin.Why?
Christy0
Christy0
Posts: 1.0K,
Visits: 2.7K
Yep!! Same Problem Here. Probably to do with getting iC7 ready to be able render with iRay, maybe can't have both together so they disable indigo.
6 Years Ago by
Christy0
Alolu
Visits: 6.3K
Do you think they discontinued it because of iray?
Posts: 5.0K,
Visits: 16.0K
This is sad. I would like for Peter to inquire the Dev team and clarify. I would want to have both Indigo and Iray be available and fully functional in future versions. Moreover I think Indigo plugin should be reinstated, revamped and fully support RT 4. Each one of those 2 engines have their own advantages. And Indigo has clear advantage in render speed over Iray. They should coexist.
6 Years Ago by
mariusjensen01 (9/30/2018)
Indigo plugin is not working in IC 7.3. IC7.just breaks down, when I try to render a picture with the indigo plugin.Why? Thank you for notifying us of this issue. We do apologise for the inconvenience caused. We now have a new patch that should resolve the problem for you. Please download it from your Member Account > Registration page.
6 Years Ago by
4u2ges (9/30/2018) This is sad. I would like for Peter to inquire the Dev team and clarify. I would want to have both Indigo and Iray be available and fully functional in future versions. Moreover I think Indigo plugin should be reinstated, revamped and fully support RT 4. Each one of those 2 engines have their own advantages. And Indigo has clear advantage in render speed over Iray. They should coexist.
Unfortunately the Indigo RT plug-in is now a discontinued product and no longer for sale. However we will continue to support it for iClone 7 users.
Christy0
Christy0
Posts: 1.0K,
Visits: 2.7K
Thanks Peter, That's great. Downloaded and did a 6 min test render in iClone 7.3, everything worked fine. Peter (RL) (10/5/2018)
Indigo plugin is not working in IC 7.3. IC7.just breaks down, when I try to render a picture with the indigo plugin.Why? Thank you for notifying us of this issue. We do apologise for the inconvenience caused. We now have a new patch that should resolve the problem for you. Please download it using the link below. https://drive.google.com/file/d/1IvLttcDXustPRZ5WWCvnZAmq6TxKDg78/view?usp=sharing
joel.lovell
joel.lovell
Visits: 553
Well, I upgraded to Indiog RT 4 (actually just the trial) and exported the scene out of IC7 (after doing the latest patch to Indigo), and it opened in RT4 and I was able to render fine. I was getting about 3.84M samples/second with my Titan X (Pascal) which was close to the Indigo Benchmark test I did. I will do a comparison of total samples vs iRay and see what the render speed difference is. Actually realized that I had to pause the render to get OpenCL going, when did so the speed jumped to about 38M samples per second.
6 Years Ago by
joel.lovell
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
joel.lovell (10/9/2018)
Well, I upgraded to Indiog RT 4 (actually just the trial) and exported the scene out of IC7 (after doing the latest patch to Indigo), and it opened in RT4 and I was able to render fine. I was getting about 3.84M samples/second with my Titan X (Pascal) which was close to the Indigo Benchmark test I did. I will do a comparison of total samples vs iRay and see what the render speed difference is. Actually realized that I had to pause the render to get OpenCL going, when did so the speed jumped to about 38M samples per second. You can use multi-GPU as well for faster speed.
mariusjensen01
mariusjensen01
Visits: 2.2K
Thanks. Indigo plugin is now working perfectly again.
