Best IRAY render settings for animation
Posted By pwnz7321 7 Years Ago
pwnz7321
pwnz7321
Last Active: 8 Months Ago
Posts: 67, Visits: 2.0K
I was curious what you guys felt were the best setting for animations in the future (when we can render IRAY in ICLONE7). IRAY renders can take quite a while and if you have the iterations too low it will look like there are dots everywhere.
My idea for quickest results would be to have low iterations about 10-20 followed by a few frames with De-Noise turned on. So an example would be have de-noise set to come on after 15 iterations for the last 5 making it 20 iterations total.
I know very little about this so maybe someone who understands it better may have a better idea.
sonic7
sonic7
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Posts: 1.7K, Visits: 19.4K
Yes, I've noticed the dots as well. But most if not all aren't apparent when you save out an image file.
The only real 'critical' subject matter I've discovered so far is 'eyes' - which seem to need a lot more iterations to look convincing (especially on closeups).
After reading this post of yours here - I tried a much lower value of 30 iterations and was surprised that it CAN be OK on some shots.
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :(  - yikes! ...
MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram iClone-7.93  3DXChange Pipeline 7.81  CC-3 Pipeline 3.44  Live Face  HeadShot  Brekel Pro-Body  Popcorn FX  iRAY  Kinect V2  DaVinci Resolve17  Mixcraft 8.1
Posts: 8.2K, Visits: 26.5K
Three comments:
a) I do not thing the "denoising" is cumulative.  I did a test "100 iteration" test, turning on denoise at iteration 1, and then another run turning it on at iteration 99.  I could not detect any difference.  I've thought about using some photo editing software and doing a "difference" between the two frames to highlight what I'm missing, but to my eyes the results looked the same.
b) Running denoise does use some time and resources, but very small, as in a fraction of a second.  There is a small hit when it "loads" the denoise capability, but after that the cost of turning it on early is minor.
c) For animation, you will need longer, not shorter, rendering times.  Why?  The noise you see in each frame will be subtly different, and what might not be noticeable on a single, static image will appear as flickering and shimmering on animation.  So that means for animation you will possibly want to render longer, and of course you'll be rendering many, many more images.
But... I'm still looking forward to seeing what we can do with it.
