jpeg image
Posted By charmed 16 Years Ago
Posted 16 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi... If you wish to include all Crazytalk features such as teeth, eyes, makeup etc in your image then you can choose to output to sequence image format (PNG, BMP, TGA). If you set the export time to say 00:00:01 it will just output a single image which contains all the changes you have made to your character.
charmed
charmed
Posted 16 Years Ago
Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)
Last Active: 12 Years Ago
Posts: 29, Visits: 98
Hi
Thanks for reply peter
I know that ct6 pro does not save the fitting points on images for use when reopening
 But I have actually got saved previously jpeg photos that do have eye shadow & eyelashes
on them.
These were saved directly to my pictures folder
I did this by click on one of the images in model,  view window, right hand save as jpeg.
Unfortunately everytime I  save an image NOW when I go to view it in my folder it saved only as the original  image, which is not a lot of good as I have that original image already.
Kind Regards.
Posted 16 Years Ago
Sadly in Crazytalk 6, saving a JPEG image does not retain the full fitting data. You will still need to adjust the fitting points again after reloading the saved JPEG file.
charmed
charmed
Posted 16 Years Ago
Hi
When I first used crazytalk I saved a jpeg image of a model that  had been changed
 but now it won't do that it only saves the image in it's original state before the changes ie: eyes teeth ect.
I can't understand why it is only saving a jpeg as the original image when it saved it with the changes earlier.
