Geoffrey James
Geoffrey James
Last Active: 6 Months Ago
Visits: 362
This is really more of a question than a compliant. Right now, I'm pushing all 11 GB of a GTX 1080 Ti. I'm considering upgrading to a system with 2 RTX 1080 Ti cards connected through SLI. Each card would have 11 GB. Will iClone recognize the new config and give me 22 GB to play with? Having all that memory would be handy for my current project. Any guidance on this would be most appreciated.
Geoffrey James Intel Core i9-9980XE 18 Cores @ 4.5GHz, 128GB @ 3000MHZ, 2 NVIDIA® TITAN RTX, 512GB SSD, 2TB SSD, 10TB HDD, 1200 Watt PS, Viewsonic 43" 4K.
Famekrafts
Famekrafts
Visits: 2.0K
You do not really need that much VRAM unless you are rendering. The last discussions I had here, showed that iclone does not recognize 2 video cards together like Blender does. But I am not sure about the SLI part. Blender Cycles uses two GPUs for rendering 2 frames at same time, does reducing the rendering time. But because iClone uses realtime rendering, it has different rendering structure and with Blender 8 realtime rendering will be added too, so I doubt using two GPUS will help. Not sure if any new updates that has changed with iClone.
CTA5, Iclone 7, 3D Exchange Pro, Character Creator 3, Popcornfx plugin, Zbrush, Blender, Vue 2014, Adobe cc suite, Spriter Homebuild Workstation (Pretty old now but still working great) Win 10, Intel i7 950, 24 GB RAM DDR3, Gigabyte x58a-ud7 motherboard, AMD R9 390 sapphire 8GB VRAM. Official Website Reallusion Store
Posts: 5.7K,
At the moment iClone still does not offer support for SLI. It has been stated that this is being looked at, and should be available in some future version.
a) As Gerry said, iClone does not support mult-GPU setups. They have not even announced a tentative timeline of when it could happen, so don't buy into an SLI setup for iClone. b) Adding a second GPU does not double your graphics RAM. Basically each card has a copy of the same data in memory, and they just render different pixels, but two 1080Ti cards will not equate to having 22GB of VRAM.
Geoffrey James
Geoffrey James
Visits: 362
Thanks so VERY much. The challenge that I'm having is a crowd scene, which is maxing out my graphics memory. Perhaps the reducible geometry feature in CC3 (not sure I'm naming it correctly) will help with this. Of course, I can popVideo parts of the crowd and reduce 90% of the scenery to a flat plane, etc. Would rather avoid this, though. Perhaps it would be best if I just asked if and where the configuration I'm considering would be overkill. I'm kinda an iClone fanatic and do all my work in the Reallusion environment. I don't see this changing. I have a decently high-end machine now, but I'm thinking of upgrading to the configuration below and am wondering where I might have overpowered or underpowered. Any suggestions welcome.
Rockoloco666
Rockoloco666
Group: Banned Members
Last Active: 6 Years Ago
Visits: 2.0K
It is recommended to use gtx gpu rather than a quadro gpu. gtx 1070 or above is good for iclone.
Rockoloco666
Rockoloco666
Visits: 2.0K
In the meantime something you could do is export your crowd characters with a lower texture resolution, for people in the the far background you can lower all they way to 256x256 textures, and for closer ones go with a resolution of 512x512. This will help you lower your memory usage, and if you are not doing close ups you can probably use 1024x1024 for your main characters and be ok
raxel_67 (9/7/2018) It is recommended to use gtx gpu rather than a quadro gpu. gtx 1070 or above is good for iclone.I also was concerned about your choice of GPU. Some high-end cards are actually not great for "gaming," and iClone uses a "gaming-style renderer." It has to do with the type of math involved. For a high-end machine like that, I'd suggest the new RTX 2080Ti. I wish that beastly card had 16GB of memory (it "only" has 11GB at the time of launch), but it should be an awesome card for iClone. I don't know if 3rd party companies like EVGA will be able to make 16GB variants of the card or not. But I think you'll be better off with an RTX than a Quadro. Of course, you could also get a GTX 1080Ti (also a fine card) for a reasonable price very soon, and wait 6 months to see what else happens in the RTX 20xx family. (EDIT: I forgot you said you are already pushing a 1080Ti to its limits. So it is a fine card for most people, but obvious you are not "most people." ) I also question (not out of jealousy) the choice of a 2TB SSD. As long as you store your project files and stuff on the 2nd drive, even 1TB leaves a lot of room for software installations and temp files. Hey, I wouldn't turn it down, but I haven't even filled up my 500GB SSD yet. I have a 1TB SSD as a "future upgrade" idea, but when I set up my SSD I told windows that "My Documents" is on my F: drive, so that helps keep a lot of junk off the SSD. It sure looks like you're in for a fun time. :)
Geoffrey James
Geoffrey James
Visits: 362
raxel_67 (9/7/2018) In the meantime something you could do is export your crowd characters with a lower texture resolution, for people in the the far background you can lower all they way to 256x256 textures, and for closer ones go with a resolution of 512x512. This will help you lower your memory usage, and if you are not doing close ups you can probably use 1024x1024 for your main characters and be okAH! I've been exporting from CC in the default each time rather than creating a avatar. I never thought of creating them with different resolutions. That should work quite nicely. THANKS!!!
Geoffrey James
Geoffrey James
Visits: 362
I decided to go with a RTX 2080 Ti, drop the system SSD to 512 and add a 2TB SSD data drive. I was gonna use the HDD for backup but decided to use an external drive instead. Thanks for everyone's help!
