Posts: 15.8K,
Visits: 31.4K
In some earlier version of iClone 7 you could rotate an object past 360 degrees further down the timeline and it would keep rotating. For example, if you started at 0 and then increased rotation to 720 at frame 100, you would get two turns. I needed this today and this no longer seems to work, OR I'm missing something. I don't even know if this is official functionality, but it was certainly convenient rather then the multiple keyframe routine. OK, so I can still do this with curve editor, but if you don't have that it seems that you're out of luck...:unsure:
Visits: 22.1K
You can certainly do this with the mouse (you need to do it in one continuous motion, don't take your hand off the mouse button, but you can rotate as much as you want with that one motion).
Posts: 5.3K,
Visits: 16.8K
If you imported something from 3DX and trying to spin it, then you are out of luck. The angle is getting reset after 360 (even with mouse rotation). This has not been yet resolved. I took the original video at FT out. So here is another one sums it up.
Great demonstration of the problem, 4u2ges. That's bizarre behavior.
Rockoloco666
Rockoloco666
Group: Banned Members
Visits: 2.0K
I just tried it with a prop imported from 3dx, i input 720 on the z axis rotation in the transform section and works as expected, and if i recall correctly the only way of going beyond 360 is by numerical input in the transform section
Note my 3dx is 6 not 7 (i'm still waiting for 64bit and pbr support and a revamped UI until then i'm not buying 7 or 8 or 9 or 10)
Posts: 5.3K,
Visits: 16.8K
Yes Raxel, it was working fine for props imported from 3DX6... But the funniest part is, that I cannot replicate that bizarre behavior I have recorded a few hours ago anymore. Out of the blue it started working! No matter what I bring from 3DX, it does spin just fine. And I hate that most about iClone. I know it is going to stop working again in the most inappropriate moment, when I need it to work in some real project. What did I do different here from what I did in the other video???
Rockoloco666
Rockoloco666
Visits: 2.0K
4u2ges (8/30/2018) Yes Raxel, it was working fine for props imported from 3DX6... But the funniest part is, that I cannot replicate that bizarre behavior I have recorded a few hours ago anymore. Out of the blue it started working! No matter what I bring from 3DX, it does spin just fine. And I hate that most about iClone. I know it is going to stop working again in the most inappropriate moment, when I need it to work in some real project.
I feel your pain, i know exactly what you are talking about
Posts: 15.8K,
Visits: 31.4K
So my problem is was that numerical input > 360 does did not work, and it should. I believe we had that functionality at one time. If you need a lot of rotations doing it using the mouse is kind of tricky. Hmm, I also tried again tonight and now it works with numerical input...:crazy: It may be the day of the week...:unsure:
Rockoloco666
Rockoloco666
Visits: 2.0K
Iclone must be doing drugs... Which makes me angry... Iclone is doing drugs and isn't sharing any :Whistling:
