Building a realistic camera look at rig
Posted By Dragonskunk 7 Years Ago
Dragonskunk
Dragonskunk
Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)Distinguished Member (8.2K reputation)
Posts: 368, Visits: 1.4K
I want to make a camera have lag when it looks at a moving subject.
Naturally a cameraman would not target like a robot there's missing a delay so I'm looking for a way for when a subject moves the camera would need to catch up with it.
I'm thinking of attaching a short cloth to the subject at one end and make the camera follow whatever is dangling from the cloth at the other end.
I just thought of this idea now and have to brush up on my cloth physics.
Can I bake a camera motion then place it delayed on the timeline?
Unless, does someone else has another way to automate a camera this way?
https://forum.reallusion.com/uploads/images/f0d5a6aa-f907-4e06-b7ab-3cc3.jpg
Threaded View
Threaded View
Forum Post Building a realistic camera look at rig By Dragonskunk ( 7 Years Ago )
Forum Post Not sure if this is what you want. I attached camera to the spine of a... By 4u2ges ( 7 Years Ago )
Forum Post Here's an idea to try. If you have one of the spring antenna props,... By Rampa ( 7 Years Ago )
Forum Post I wrote up a request for an improved "Look At" feature a long time... By justaviking ( 7 Years Ago )
Forum Post I though of an idea. Add another avatar. Give it the same motion as... By Dragonskunk ( 7 Years Ago )
Forum Post Probably easiest just to set an ease-in transition curve on the... By Rampa ( 7 Years Ago )
Forum Post [quote][b]Rampa (8/20/2018)[/b][hr]Probably easiest just to set an... By Dragonskunk ( 7 Years Ago )
Forum Post [quote][b]Dragonskunk (8/20/2018)[/b][hr][quote][b]Rampa... By Rampa ( 7 Years Ago )
Forum Post >@4u2ges I don't know what you are trying to explain.<... By 4u2ges ( 7 Years Ago )
Forum Post So this is with the default spring of the antenna thingymabob. It's a... By Rampa ( 7 Years Ago )
Forum Post [quote][b]Rampa (8/21/2018)[/b][hr]So this is with the default spring... By Dragonskunk ( 7 Years Ago )
Forum Post Here is the same clip, but with a rotational spring. Also a bit more... By Rampa ( 7 Years Ago )
Forum Post I also think the most realistic "Hand-held Camera" would be the... By toystorylab ( 7 Years Ago )
Forum Post I'm itching to get to iClone but so much to do. One thing I want to... By Dragonskunk ( 7 Years Ago )
Forum Post [quote][b]Dragonskunk (8/21/2018)[/b][hr]I'm itching to get to iClone... By Rampa ( 7 Years Ago )
Forum Post A quick Test according to Rampas suggestion... Used "Antenna01" from... By toystorylab ( 7 Years Ago )
Forum Post @toystorylab: That looks pretty convincing to me. Something to add to... By animagic ( 7 Years Ago )
Forum Post I appreciate the "spring" experiments. Good stuff. Looking at TSL's... By justaviking ( 7 Years Ago )
Forum Post Here is a spring delayed tracker for download and use. Think of it as... By Rampa ( 7 Years Ago )
Forum Post I knew this would be a fascinating thread and quite amazing results. I... By Dragonskunk ( 7 Years Ago )
Forum Post So if the camera stays in one place and pans, the delay tracker tripod... By Rampa ( 7 Years Ago )
Forum Post RE: Building a realistic camera look at rig By Dragonskunk ( 7 Years Ago )
Forum Post This scene is what I wanted a more stable fluid motion to the camera.... By Dragonskunk ( 7 Years Ago )
Forum Post Is there a spring setting I am missing somewhere? I have tried all of... By gordryd ( 7 Years Ago )
Forum Post Th [quote][b]gordryd (8/24/2018)[/b][hr]Is there a spring setting I am... By Dragonskunk ( 7 Years Ago )
