DJAnim8
DJAnim8
Visits: 24
I've tried to search the forums for this support, because I can only imagine other 4K monitor users have had the same issue, but can't find a solution. Using CrazyTalk 8.13 Pipeline, the GUI text is too small on my 4K monitor and I can't read it. I tried to set my text scale to 200%, but it doesn't seem to affect it. I also looked in the preferences, but didn't see an option to increase the interface text like iClone 7.22 has (although that is still a bit small for me, I can at least read it a bit easier).
Is there a setting to increase the text? Or is it in the works for a future update?
Thanks for the help
Last Active: 5 hours ago
Posts: 23.1K,
Visits: 36.5K
Unfortunately CrazyTalk 8 doesn't support 4K or other Ultra HD resolutions. It is recommended to change your resolution to 1920 x 1080 for optimal performance. With 4K screens becoming more common now, the next version of CrazyTalk will likely support 4K just as CrazyTalk Animator 3 does.
DJAnim8
DJAnim8
Visits: 24
Will the next version be a sub release? or a full release? If it's a full release, can a sub release be developed with the 4K support? Switching to 2K gets a bit annoying since all my other 3D and 2D software runs from 4K.
Posts: 23.1K,
Visits: 36.5K
Unfortunately there are no plans for any new updates to CrazyTalk 8.
AnaCrisan
AnaCrisan
Visits: 23
How can I use Crazy Talk Animator 3 in 4K? All menu is too small. Thank you
Posts: 23.1K,
Visits: 36.5K
AnaCrisan (9/6/2018) How can I use Crazy Talk Animator 3 in 4K? All menu is too small. Thank youAll you need to do is go into Preferences (CTRL+P / CMD+,) and put a check in "4K Resolution - Enlarge Font and UI".
6 Years Ago by
