hmadden
hmadden
Visits: 3.0K
in composer mode, I brought in a modified character from photoshop. however, when I exit to stage mode the modified character went back to the original. What did I miss? Thanks
jlittle
jlittle
Last Active: 5 hours ago
Posts: 1.9K,
Visits: 17.1K
When exiting composer mode the character will use the last (usually the default) sprites selected for each body part. It sounds like you added some new sprites. If so, then you need to use the sprite editor and select the new sprites for each body part and then save the character with those sprites selected. Jeff
