CTA3 Pipeline - G3 Elastic Motion loops from beginning even with Align to ball
Posted By Chucks -7600 6 Years Ago
CTA3 Pipeline - G3 Elastic Motion loops from beginning even with Align...
Chucks -7600
Chucks -7600
Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)Veteran Member (830 reputation)
Posts: 11, Visits: 95
Using CTA3 Pipeline (Mac version) - After importing a ball as a prop, I applied the SNAIL G3 Elastic Motion with the Align to Ball feature but the Snail continues to begin from the same starting point every time. Is this because a Prop is not able to act as an animated object? Do I need to convert it to another format or something?
I cannot find a solution, even after reviewing the User Guide and watching the videos.
Please help if you can.
kylelee
kylelee
Posts: 462, Visits: 4.2K
Hi, I have tried to repeat your issue, this seems bug but there has a workaround.
I found at the first frame to import clip is work, but when after the first frame importing a clip will not support align.
And it does work if clip and clip have one frame to separate when importing clip.
https://forum.reallusion.com/uploads/images/cb732b0e-b684-47cd-86c9-ab1c.gif
Chucks -7600
Chucks -7600
Thank you. I will give it a try!
