PSD File Import Problem
Posted By lancebradstreet 7 Years Ago
lancebradstreet
lancebradstreet
Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)Veteran Member (751 reputation)
Last Active: 7 Years Ago
Posts: 8, Visits: 105
I figured out the problem, I had to change the color mode to RGB.  If the color mode is set to CMYK then the file won't import into CTA3.  I'm not sure if that's a bug or if it's expected.
lancebradstreet
lancebradstreet
I have a group of sprites for a prop in Photoshop that I cannot open in CTA3.  I get an error that says:
"The PSD file cannot be recognized. Please try to save this file again in your PSD editor, and then reload to CrazyTalk Animator."
The original artwork was done in Illustrator and exported as a PSD.  I then opened the file in Photoshop and merged some of the layers and organized things and then saved as a new file.  I'm not sure if using artwork originally created in Illustrator is causing a problem.  I did a test by creating a new PSD file and drew a simple rectangle and that imported into CTA3 without any issues.  I've attached an image of what the layer manager looks like.  Has anyone run into this problem before?  Thanks.
https://forum.reallusion.com/uploads/images/555c8b0a-e68b-48c3-9815-3240.png
