Darren01
Darren01
Last Active: 7 Months Ago
Visits: 4.1K
we have some very talented animators here that can think right outside the box to overcome some of iClone's limitations nice work on those underwater scenes
_________________________________________________________
Posts: 5.3K,
Visits: 16.8K
Here is fairly quick and dirty. Bottom caustics only. Quality of the caustics video is lousy (ripped first available from YouTube). Hi-res videos from Mike's link would probably do better. Basically I have a plain up high with the video in opacity channel (had to play with that video in HitFilm, inverting it, desaturating,.. etc). And a spot light above it:
I like the idea of illusionLAB. Could be fun to play with opacity channel. Here is static one, but rotated:
Visits: 22.1K
It's not the shadow catcher -- you can get rid of that. I won't speak for IllusionLAB but the sample he sent me seems to indicate that you need a VERY fine "mesh" to get the reflections to show properly from the spotlight. What he did was create a plane and put this very fine opacity map on it that the spotlight shone through (and used an emmissive GI surface to get the "blue light" but, again, this isn't the important part -- the important part is that very detailed mesh). I've actually tried this myself and, even using his project, I can't get the same underwater results I would need using more sophisticated caustics (he uses a very simple noise pattern and "animates" it just by rotating. I want actual caustics and while I have a pattern for them I can't get it to look right. Yet. I'm still hopeful). In case anyone else wants to try, what I'm using is this: https://www.dualheights.se/caustics/There's a freeware version there that is more than adequate for testing -- and if I could ever get this to work I'd pay for the more advanced version, but I can't yet. Yet.
gordryd
gordryd
Last Active: 4 Months Ago
Visits: 8.1K
IllusionLAB - I've tried several different ways to use spotlight shining through opacity object but I am not getting the impressive results I see in your post. Would you be willing to give us a general overview of the steps you took to achieve this effect (the caustic shadows and the light rays)? I just noticed the Shadow Catcher as one of your props -- maybe that is the key? Thanks,
@TSL - That was very cool. I thought the underwater effects were very fine.
Here is a different implementation of caustics, used on a "spirit lady" proof-of-concept...
toystorylab
toystorylab
Last Active: 3 days ago
Posts: 4.6K,
Visits: 29.9K
After seeing this thread i decided to try it myself cause i never did an "underwater" before :pinch:Used the Popcorn FX God Rays to try to simulate sun from above... Lots of Popcorn FX (Bubbles, Clouds, Fog, ...) and in post a pinch of "Hitfilm Fluid Distortion"...
Visits: 22.1K
The project file would be great, because I have used my own caustic textures (which are fine) and can't get anything to work in iClone (the best I can get doesn't even begin to approach what I could do in Max or Maya). I'd just love to see how you're doing it with the proper lighting (obviously me trying with my own plane and caustics I'm missing something).
illusionLAB
illusionLAB
Visits: 4.8K
Sure... do you want a project file or just the texture for the caustics?
Visits: 22.1K
I have tried repeatedly to create caustics in just the manner you are describing (with no success at all). I don't suppose you'd share that file (just the cutdown one with the caustics)? I would LOVE to get that working.
illusionLAB
illusionLAB
Visits: 4.8K
Underwater, like many lighting scenarios, is best emulated by working over a 'real life' reference. Light source is always only from above... and very soft, so a GI plane emitter is a good place to start. In the image I created I've also added a spotlight to create the 'caustics' - you can't see it (2-sided off), but there's a plane with a noise map in the opacity channel which only allows light through the cracks. Animating a slight move in the "caustics gobo plane" makes for quite a convincing effect. The rest of the lighting on the dude is using a 'blue fog' - no IBL it will kill the look. Obviously, the deeper you go the less power the caustics have.
