Fortnite Project
Posted By will2power71 8 Years Ago
will2power71
will2power71
Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)Distinguished Member (9.6K reputation)
Posts: 389, Visits: 2.8K
I'm going to try this again tonight with a CC3 base, but it was really encouraging to see that you can get a pretty decent rendition with the tools that are out there now. Ken is my personal favorite, so I want his to look as good as I can make it. Here's the first test render with a DAZ topology
https://forum.reallusion.com/uploads/images/675df733-b781-41e5-89ce-ce6a.png
will2power71
will2power71
I had to do a lot of rethinking when it came to working with the Fortnite Geometry. At first I thought I would be able to get away with using the DAZ body and making a custom head morph, but I've since had to re-think the whole thing. The DAZ Geometry is good, but it presented too many problems with trying to achieve the look I want. So What I ended up doing is creating the body Geometry from scratch using Topogun, and a lot of other tools, but I'm pleased to say that it was definitely for the best. This is the result:
https://forum.reallusion.com/uploads/images/0e4c2a9c-0ca4-4aa5-9565-9e2f.jpg
I ended up with much cleaner topology in the final result. The thing is that You can work with someone else's geo and end up frustrated because there's something just not right here or there. This also made it possible for me to set things up where for each size figure, all I have to do is import the head Geometry as a morph/blendshape so that I can essentially have one geometry for each size figure. In the end I decided not to try to match the Fortnite shapes entirely, but found the best features of each size and fill in the blanks with my own take on each. This guy is ready for UVs and rigging, and I'm going to do the same thing for the larger sized figures. It's taught me a lot about topology and the end result is exactly what I wanted instead of being "close enough". I'm looking forward to diving into the rigging process for each one and seeing the result on screen. I am planning to animate them in iClone so I'm looking at a good joint based rig. Depending on the result, I may try to do a more fully realized work in Maya but for right now because it's just me --I think iClone is still one of the better fits.
will2power71
will2power71
The really exciting thing is that it's easy to make a lot of different variants for what you want to do. I got a lot of mileage out of Topogun for creating the hair, beard and eyebrows as well as the clean topology. Hopefully this GIF will display properly so you can see what I mean.
https://forum.reallusion.com/uploads/images/114dcdd1-b9db-4bf1-b4ee-8d18.gif
Wrestling with someone else's geometry is it's own special nightmare but if you are willing to put in some effort, you can get exactly the results you want.
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
Respect for your project. And nice to see your results so far...
will2power71
will2power71
I had some stumbling blocks in a major way with the topology and I had to make some changes. The parts of the body I really wanted to implement I'm having to put aside for a little while. I still wanted to move ahead with my project so I reworked the male  body while I continued to work on the retopology of the heads. I am keeping the heads and bodies separate for the moment. The trouble I ran into was that the hand and feet topology was too dense to work. I'm still planning to use the shapes but I am having to retopologize those body parts in a big way to decrease the polycount. In the mean time I came out with a version 2 that has better topology.
https://forum.reallusion.com/uploads/images/e2b77c1d-53ae-4a70-9e08-3db6.png
I worked out a heroic body and regular body for the different characters with the small/medium body types. I've decided I'm not going to do the Large frames at this point --their proportions are just too far out for my tastes. Work continues with the rest but I'm pleased with the results right now. Here are the male heads I've retopologized.
https://forum.reallusion.com/uploads/images/38e39748-b190-4828-b4e6-d531.png
Work continues slowly but surely. I am doing the UV Maps for the base body this week. Since each head is the same topology, I only have to do one UV Map and I'm good to go.
I've decided that I'm going to cheat a little. I'm going to be using Mixamo for the body rigging and I'm going to take the finished rig into Maya  and add the face bones to the face of the model when I'm ready to go forward. With this setup, I can use Akeytsu to do the animation. There are a couple of reasons for this --I would like to be able to move back and forth between Cinema 4D, Maya, iClone, and Unreal engine. I deliberated on this for a long time because I wanted to maximize my effectiveness when working with animations. iClone offers a lot in house but I've decided to do the animating favoring joints and morphs which they all support. The key factor that caused me to select Mixamo instead of the full iclone skeleton is that Mixamo offers control rig options in both Maya and Cinema 4D --and has a retargeting script in Unreal engine that makes things pretty painless. With joints for the face and morphs in the Morph animation section, I can have  pretty full feature set across all the applications with a minimum of hassle. The Mixamo rig is also supported in Anima 3.5 which works Natively in Cinema 4d.
It wasn't an easy decision, but I had to balance the tools I needed to get the finished product. iClone isn't very strong with crowd sims and I wanted to minimize the amount of time working with them, while being able to setup and use custom content with Anima. There's another reason why I'm choosing this route rather than trying to work with Character Creator 3 at the moment. I love the iclone environment. It's easy to work with, the materials are simple and I think it can't be beat when it comes to special effects for a hobbyist. This is more something that affects me as an animator and the look I'm trying to achieve. Toon figures require a lot extra when it comes to animating that the CC3 figures can't give me right now, and that's rigging for custom geometry. Right now, if I want to put a toony set of eyebrows on a dwarf, I can add them as a piece of clothing, but I can't add extra rigging to them. If I create a custom character, I can create face bones that mirror Iclone, but then I can add those extra bones that give me the functionality that I need in order to make it work the way I want it to. I'd rather just go ahead and rig the clothes outside of iClone so that if I need a cape with bones for some reason, I have them. I can bring everything in as an fbx and just apply the materials and render it with some forethought. Worse comes to worse, I can rig the whole thing and just bring in the finished animation when I'm done and render it. It's not the ideal setup but it affords me options that I don't have in iClone at the moment.
