BUG iClone7.21 cant access folder shortcuts
Posted By Delerna 7 Years Ago
Delerna
Delerna
Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)
Posts: 1.5K, Visits: 14.8K
No, that's not the answer either, I just removed it again and it still works   ???????????????
Whatever. It works now
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
Delerna
Delerna
Ah huh. Figured it out. Thank you very much you 2 for pointing it out. Now I can do what I am trying to do to organise my contents.
Here is what it was for anyone interested, especially reallusion.
When you right click on a file and select create shortcut, the shortcut gets the same name with  - Shortcut on the end.
For all the contents shortcuts I created that way when I first started (before I made my shortcut creater and modifier) I wrote another program to remove some text from files names in a folder and its subfolders.
So I removed  - Shortcut from all the content shortcuts and that works fine.
When I did the folder shortcuts that worked I was just testing that it would work so I didn't remove the  - Shortcut and it worked fine.
When I started creating the folder shortcuts I actually want I removed the  - Shortcut and they don't work.
I just created a new folder shortcut and left  - Shortcut and it works in iClone 7.21. So I was wrong, its not the new version that caused the problem. It's just the problem I made occurred just after I updated iClone and stupid me jumped into blaming reallusion's new version of iClone instead of myself.
https://forum.reallusion.com/uploads/images/a6785715-1ce7-4c32-b6fd-df9d.png
Delerna
Delerna
I Will double check. But yes I did create new folder shortcuts.
I hope I did something wrong, and looks like I did....If so then problem solved
Posts: 9.2K, Visits: 22.1K
Folder shortcuts definitely work for me in 7.21.
Posts: 15.8K, Visits: 31.4K
Delerna, I created some folder shortcuts and they do show up for me as proper shortcuts in 7.21. Did you try to create a new shortcut and see if that works?
Delerna
Delerna
My bad. I should have posted this here
I have linked this post into that post now
Delerna
Delerna
I would post this into feedback tracker but.
I am logged into Forum and go to home and click on the link to feedback tracker. It used to open up with me logged in but now it wants me to log in
So I tried logging in half a dozen times and it wont accept my login. And yet I can login to the forum with the same typing ????????
Anyway. I use folder shortcuts to help me organise my content and the way I do it also helps iClone to operate faster for me, especially when I'm using the contents input.
Been working fine for a long time, might check but I'm sure it was also working in iClone 6. Anyway, reguardless.
Its been working in iClone7 as can be seen in this image
https://forum.reallusion.com/uploads/images/6d6b9f37-ace7-4d34-96d7-3b01.png
But I updated iClone to 7.21 yesterday and now it doesn't work with folder shortcuts. Reallusion, has this ability been removed deliberately or is it a bug created from the updates that have been done?
Here is an image that shows it
https://forum.reallusion.com/uploads/images/873c29df-b939-4045-8254-c483.png
