An Interesting Error
Posted By RyderHS 8 Years Ago
RyderHS
RyderHS
Posts: 84, Visits: 405
Thank you very much.
Reallusion Certified Director
Posts: 5.3K, Visits: 16.8K
There is actually an easy fix for the Spotlight bug:
animagic (2/8/2018)
4u2ges (2/8/2018)
I am with Indigo RT4 where spotlight does not work anyway and usually using emissive objects instead.
You can try the same.
So you can use iClone scenes in Indigo RT4? I wasn't clear on that since for Indigo 3 RT we used a special iClone-specific version. Using Indigo 4 would make it a bit more interesting. Seems that it is still in beta though.
I have not touched it for a while since the release of IC7, but it seems they now have a stable version available (got to test it at some point). Yes, RT 4 would work with iClone 7. I have both RT3 and 4 installed in different folders and can switch with just pointing to the right executable in iClone. But once you get a taste of 4 you would never go back to 3 (that is if you still use Indigo). Aside from other improvements, the main advantage is a blazing render speed with Open CL. Still not enough to animate complex scenes, but for something simple (simple still needs to be defined in terms of lighting, poly counts, specularity.. etc) it is quite doable.
Here is a speed comparison I made a while ago https://forum.reallusion.com/FindPost329996.aspx
raxel_67 (2/8/2018)
Spotlights and Point lights will always show in indigo, in kai's tutorial he mentions that, also mentions that if you are going to use them they should be out of the camera view
They sure would. But in iClone 6 Spotlight would show up at the point of placement, while in iClone 7 only light ball of the Spotlight would be at the placement location. The dummy enclosure is always at the center and it is deformed. It is a bug.
Rockoloco666
Rockoloco666
Group: Banned Members
Last Active: 6 Years Ago
Posts: 762, Visits: 2.0K
Last Active: 5 Months Ago
Posts: 15.8K, Visits: 31.4K
4u2ges (2/8/2018)
RyderHS
RyderHS
Understood, thank you.
Yes, it appears to be an iClone 7.2 bug. Replacing spotlight does not help. And it seems now the "ghost" mesh is nothing
but a deformed spotlight dummy enclosure reveled in Indigo right in the center of the scene (regardless where the spotlight itself is positioned).
RyderHS
RyderHS
I added a new spotlight and delete previous. But problem is continuing.https://forum.reallusion.com/uploads/images/9af9d565-08bc-4f18-9e60-15c9.jpg
RyderHS
RyderHS
:laugh:
Rogue Anime
Rogue Anime
Posts: 548, Visits: 3.4K
It's alive... IT'S ALIVE!!  :laugh:  ~V~
       Val RogueAnanda
https://forum.reallusion.com/uploads/images/e82de505-c57a-40b9-8cb0-9f87.png
