jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Did you check that you have the correct sprites assigned to each angle? Go to composer mode and rotate the the character thru each angle and check that the sprites are correct. I know that sometimes when you assign a sprite to an angle if you use the wrong mode it will assign the same sprite to ALL angles. Jeff
kylelee
kylelee
Visits: 4.2K
You can pass by this issue to Technical Support and provide your character for further investigating. This issue may is losing the 45 angle sprite. It would be needed to check this character.
michel.gervais
michel.gervais
Last Active: 7 Years Ago
Visits: 23
Hello everyone, I have a problem lately when I'm using the 3D motion key editor with G2 characters. When I attempt to change the angle of the character, sprites are not following (see attachment). Is there anything I'm doing wrong ? Thanks
