Using a spoylight with CC long hair (help please!)
Posted By elliespotter 9 Years Ago
elliespotter
elliespotter
Posts: 258, Visits: 1.5K
Hi Guys,
I am using a customised CC avatar with CC Long Hair and have run up against an interesting little problem with lighting, using a fill in spot.
Here is a view with light turned off (avater lit from above).
https://forum.reallusion.com/uploads/images/d7cab65e-157f-416e-8b2f-81b0.png
Now here is the avatar with the fill in spotlamp turned on:
https://forum.reallusion.com/uploads/images/6f7832af-f3cc-470b-b159-9eca.png
As you can see  an interesting effect it really is not what I was aiming for which is to lighten some of the shadows and provided a realistic stage lighting effect.
Has anybody come across this issue and/or have any ideas how to resolve it?
I'm running iClone 7.2 by the way.
Kind regards,
Alex
Threaded View
Threaded View
Forum Post Using a spoylight with CC long hair (help please!) By elliespotter ( 9 Years Ago )
Forum Post I'm going to guess this can be fixed by adjusting the shadow bias --... By Kelleytoons ( 9 Years Ago )
Forum Post [quote][b]Kelleytoons (12/28/2017)[/b][hr]I'm going to guess this can... By elliespotter ( 9 Years Ago )
Forum Post Based on other hair-transparency problems being reported, it looks... By animagic ( 9 Years Ago )
Forum Post Hair does seem to be a problem with iClone. I am so envious of the... By elliespotter ( 9 Years Ago )
Forum Post Alex, the other setting you might try is Alpha Threshold. It's located... By animagic ( 9 Years Ago )
Forum Post Thanks Animagic, Adjusting Alpha Threshold on the hair did very... By elliespotter ( 9 Years Ago )
Forum Post This is indeed an odd behavior. I tried to simulate with multiple... By 4u2ges ( 9 Years Ago )
Forum Post [quote][b]4u2ges (12/30/2017)[/b][hr] This is indeed an odd behavior.... By elliespotter ( 9 Years Ago )
Forum Post OK Alex. So right out of the box I should have been getting a... By 4u2ges ( 9 Years Ago )
Forum Post Thanks 4u2ges, Maybe somebody at Reallusion might pick this one up... By elliespotter ( 9 Years Ago )
Forum Post I'm getting exactly the same result. Something with GPU drivers would... By animagic ( 9 Years Ago )
Forum Post It works fine on my system... Things like this are very annoying... By toystorylab ( 9 Years Ago )
Forum Post It seems that it is something to do with my system then. Perhaps I'll... By elliespotter ( 9 Years Ago )
Forum Post You could, of course, be *absolutely* sure what it is by just using a... By Kelleytoons ( 9 Years Ago )
Forum Post [quote][b]Kelleytoons (12/31/2017)[/b][hr]You could, of course, be... By elliespotter ( 9 Years Ago )
Forum Post Far be it from me to get in between anyone's prejudices, but given... By Kelleytoons ( 9 Years Ago )
Forum Post I don't question those results Kelleytoons but I would be concerned... By elliespotter ( 9 Years Ago )
Forum Post [quote][b]elliespotter (12/31/2017)[/b][hr]I don't question those... By Kelleytoons ( 9 Years Ago )
Forum Post Still 50/50 as I see it. I bet OP would not have those problems in... By 4u2ges ( 9 Years Ago )
Forum Post [quote][b]4u2ges (12/31/2017)[/b][hr]Still 50/50 as I see it. I bet OP... By elliespotter ( 9 Years Ago )
Forum Post FT Issue 3726 . Hopefully it'll be resolved in a next update By 4u2ges ( 9 Years Ago )
Forum Post Friends - I have run into this multiple times. I fixed this problem... By Rogue Anime ( 8 Years Ago )
Forum Post Well, would you believe it? While I was mulling over what graphics... By elliespotter ( 8 Years Ago )
Forum Post Not a waste at all! Glad you are set - Always ready to share ~V~ By Rogue Anime ( 8 Years Ago )
