BVH Motions with no T-Pose in 3DXchange
Posted By Lamias 7 Years Ago
Lamias
Lamias
Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)Distinguished Member (5.4K reputation)
Posts: 646, Visits: 2.9K
Hey there guys, I was hoping you could help me with an issue. Smile
I have some BVH motions that I wanna convert to iMotions. The problem is that they start performing immediately, with no T-pose in the beginning, so the motion results inside Iclone are very wrong.
Now the question: I already have a ready made BVH T-Pose in my motion library. Is there a way to use that ready made T-Pose, and integrate it somehow with the motions that start immediately, to produce correct results??
I hope I am making sense. I was hoping to avoid making a custom T-Pose for 400 BVH motions, by using the ready made BVH T-Pose in the beginning of said motions, in order to produce correct results in Iclone.
Any thoughts? Smile
___________________________________________________________________
My YouTube Channel
Phoenix   Wink
7 Years Ago by Lamias
Me3Dtoo
Me3Dtoo
New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)
Group: Banned Members
Last Active: 7 Years Ago
Posts: 23, Visits: 184
Hello,
All bvh (.ini) profiles do not match up with all motions.
One way to ensure that your group of 400 motions will work with your tpose.... is to create an "MM" file.
You basically add that tpose in your bvh (.ini) file
Then, (Before) you use that specific set of motions.... You Load that "MM" file.
Now everything works as expected.
What tool are you using to edit / create bhv "Profiles?"
7 Years Ago by Me3Dtoo
Posts: 9.2K, Visits: 22.1K
You don't need a t-pose to use those BVH motions -- most of the ones I've converted don't have them either.
I'm not sure what your problem is inside of iClone, though -- what happens is you bring the BVH file into XChange, map it to the right bones (and there will be a t-pose you can use there to map them) and then import as iMotions.  They *should* work just fine inside of iClone (they certainly don't need to start with a t-pose).  You using iClone 7.1?  It's gone a LONG way towards making animations flow better.  Just make sure you have all three checkboxes checked for the animation options.
Me3Dtoo
Me3Dtoo
Lamias,
Kellytoons is correct.
What I meant by saying, "You basically add the tpose to the bvh (.ini) is....
~ Every bhv has a certain way the bones are named and a specific quantity of bones.
I use a bvh editor to match iClone bone names to any motion.
~ I create an "MM" file for these motions.
~ Now I can batch export numerous files.
...without the need to repetitively mapping bones.
Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)Distinguished Member (37.4K reputation)
Posts: 8.2K, Visits: 62.4K
When to characterize it, you do indeed need a t-pose if you want the joints rotations be what you expect.
If all of your 400 BVH files use the same skeleton, you only need to put one in a T-pose. Then you can import the rest into your motion library and have it convert them with the same settings.
If there is not an existing T-pose in that 400, then you just import one, adjust it into a T-pose, and then import the rest.
Lamias
Lamias
The problem I am facing is this:
https://forum.reallusion.com/uploads/images/babe5a28-d3c0-4dfe-9275-9988.jpg
That's how most of the motions start. I understand that I can issue a T-Pose manually, but it's a lot of work and I have over 400 bvh motions, so I was looking for a more productive route.
Update: I used the ready made T-Pose in 3DXchange and then I loaded the motions in question. When I converted to a non-standard, it converted them as well, as Rampa suggested. However, I did it with 3DXchange 6.5.
3DXchange 7 doesn't work for some reason. When I do Rampa's process in 3DX 7, the "apply to Iclone" button doesn't do anything when pressed, and 3DX 7 doesn't let me export the motions in IC format, giving me the following error:
https://forum.reallusion.com/uploads/images/e6dea327-2025-45e1-9131-3020.jpg
Any ideas why this happens? 3DX 6.5 does it, but 7 fails to. Sad
My YouTube Channel
Phoenix   Wink
There's a bug in 7 -- the workaround is to have a saved Characterization profile.  Once you do this (and load it in) then you can apply to iClone or save properly.
Lamias
Lamias
Yes, that did it Kelley!
Thanks guys, problem solved. Smile
My YouTube Channel
Phoenix   Wink
jgrant
jgrant
Last Active: 8 Months Ago
Posts: 170, Visits: 2.1K
Hi Rampa,
Long time no talk. I’m back at working with IClone on a new film and I want to use BVHs. As you have demonstrated here, I will have to set a Key Pose for a number of files I have. Is there a faster way than manually adjusting? I’m wondering if you have time to chat about this or provide a more comprehensive walk through. I’m happy to compensate you for your time. With thanks,
